20 Most Recent
SRT-35R Radar Detector Questions & Answers
I have a Whistler 35
All Whistler's that are not battery powered run on 12 volts with the center tip postive. You can order a power cord by calling 800-531-0004 or whistler's online store at
www.whistlergroup.com.
A friend gave me a
That model is not battery powered. It requires a 12 volt power cord connected to your lighter socket to operate. You can purchase a power cord at any electronic parts store or from Whistler by calling 800-531-0004.
Power is there but no visual display
does the unit beep at all? Is the fuse ok in the units' power cord? Check these out. If the fuse is bad you can replace it with a 2 amp fuse from an auto parts store.
Whistler 35R just quit. fuse and pwer cord is fine.
Orginal whistler power cords do not have LEDs lights in them and there is no electronics in the plug - 12 volts in, 12 volts out. Sounds like you have a bad cord or a cord that is meant for a GPS unit or other 5 volt device.
Whistler35r ops manual
its the bracket release button - if you're talking about a button on the left side of the unit. This allows the unit to properly be removed from the windhsild bracket.
Need help with 35R
checked the lighter socket fuse? Does anything else run ok on the lighter socket?
Specs for whistler 975 power cord what's the output
Product detailsCar charger For Whistler 925 945 975 1125 1200 Series Radar Detector Power Cable Power Payless All products are new and fully-tested OEM equivalent replacement parts Input voltage: 100V ~ 240Vac 50/60 Hz Overload protection Short circuit protection Over Temperature protection Power Saver Protection 100% HI-POT tested 100% cycling burn-inContact us for any question before leaving none-5 star feedback.Specialty Service in Power Supply,Satisfaction guaranteed ! How much power does a dash cam usePlease note that this is a quality compatible adapter, picture is justfor reference. It may looks different from the physical adapter youreceived. Sometimes, we even will send you a brand name adapter that is compatible with the one advertised.Source Link:https://www.newegg.com/toplab-hrnbl-b07kdjxn9l/p/0FB-06J3-00046?Description=cr93,whistler&cm_re=cr93,whistler-_-0FB-06J3-00046-_-Product
How to perform a factory reset on whistler WS1025 scanner
Configuring Your Scanner
Preprogrammed Frequencies
Your scanner includes 153 preprogrammed
frequencies, which you can load into Channels
1 to 153. For a list of these frequencies, see
"Preprogrammed Frequency List" on page 23.
To load the pregprogrammed frequencies:
1. Turn off the scanner and then turn it on again.
2. While WELCOME message appears, press PGM.
3. Load -Fr- appears, then YES--Ent and No --
CLEAr appear alternately.
4. Press ENT to load frequencies or CLEAR to
cancel.
Programming Channels
If you do not have a list of frequencies in your area,
refer to www.radioreference.com.
1. Press PGM. PGM appears.
2. Enter the channel number (1-200) where you
want to store a frequency, then press PGM again.
3. Use the number keys and • to enter the frequency
(including the decimal point), then press ENT.
4. To program the next channel in sequence, press
PGM and repeat Step 3. To program a specific
channel repeat Steps 2 and 3..
• Your scanner automatically rounds down to
the closest valid frequency. For example, if
you enter 151.473, your scanner rounds it to
151.470.
• If Error appears and the scanner beeps three
times when you press ENT, start again from
Step 2.
• If the frequency is already stored in another
channel, the scanner beeps three times and
displays -dUPL- (duplicate) and the lowest
channel number where the frequency is already
stored. Press TUNE/CLEAR to cancel. Press
ENT if you still want to store the frequency.
What's vg2 mean on 1530 Whistler
The VG-2 button is to engage VG-2 Cloaking Technology. From what I can see VG-2 Cloaking Technology is a way the detector has of avoiding being detected by authorities in areas where the use of radar detectors is prohibited. I am not in a position to say how effective this is, I suggest you refer to reviews. I have only researched the meaning of VG-2.Rider here: Please do your own research on the effectiveness of this technology on this - or any - detector.Of course the best way to avoid being picked up for speeding is not to speed. (But you knew that..)
NEED CODES AND HOW TO SET A WHISTLER XRT 335
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder
it had some spark issue which wasn't easily fixed. you can go there and try free
