20 Most Recent KitchenAid Superba KSRG25FK Side by Side Refrigerator Questions & Answers
My refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
4/14/2018 5:37:18 AM • KitchenAid... • Answered on Apr 14, 2018
Water started pouring out of
Cindy, it’s either the water inlet valve that fills your ice maker or the ice maker itself that is bad. The ice maker itself controls the valve. It should come on for about 7 seconds to fill the tray. The valves do fail but not as often as ice makers fail. Its also possible that the fill tube to the ice maker is blocked with frozen water but since it made one tray that is unlikely. If you know someone that knows how to test the valve it would eliminate the decision of replacing the ice maker or the valve. Otherwise I would recommend changing the ice maker first. Hope this helps.
2/11/2018 3:57:03 PM • KitchenAid... • Answered on Feb 11, 2018
2answers
Water is leaking into the ice tray freezing all the ice cubes together
That maybe it or it may be your preception, If the heater in defrost is over heating during the defrost cycle you can get the same results
1/1/2018 12:37:43 PM • KitchenAid... • Answered on Jan 01, 2018
KitchenAid side by side refrigerator center wall is hot to the touch
Condenser coils dissipating heat.
8/6/2017 4:46:36 PM • KitchenAid... • Answered on Aug 06, 2017
HI, I have a KSRL25FRSS00 side by side. The
There is a heater in the ice tray that is supposed to thaw the cubes a little bit so they don't stick to the edge of the tray. When the heater does not work the ice sticks and the motor wont dump them out. You can see more info and comments and how to here: http://www.appliancepartspros.com/repair-help/kitchenaid-refrigerator-ksrl25frss00-repair/ksrl25frss00-ice-maker-wont-dispense-ice.html
7/28/2017 2:35:13 PM • KitchenAid... • Answered on Jul 28, 2017
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
5/4/2017 5:22:59 PM • KitchenAid... • Answered on May 04, 2017
2answers
Getting only ambient temperature from the frige
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care.
6/13/2016 4:45:15 PM • KitchenAid... • Answered on Jun 13, 2016
Kitchenaid superba frig.past 2 days high pitched over temp light alarm goes off every few hrs in between reset we cleaned coils temp in freezer seems fine but frig is not please help
May be frozen up or plugged up. Remove all food. Unplug it and open the doors. Leave for 24 hrs. Clean up any water. Clean out the tray underneath. Usually access from the front if you can pop off the trim panel under the doors. Pull it out. Remove the back. Inspect for large amount of debris. Check any cooling fins etc. use a vacuum with a hose to clean it all out. Plug it back in and try it.
9/15/2015 1:28:39 AM • KitchenAid... • Answered on Sep 15, 2015
2answers
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly. Go through this troubleshooting help links. -------------------------
This is list of refrigerator problems, which is normally faced in refrigerator. You can go through the details, by clicking the link below:---
-------------- Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- Both refrigerator and freezer not cooling properly in refrigerator? http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ---------- The ice maker not working: --- http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
------------ Compressor not running on refrigerator? http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html -------- Water dispenser not working on refrigerator? http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
7/13/2015 1:42:54 AM • KitchenAid... • Answered on Jul 13, 2015
No ice.... refrigerator getting warm..... freezer also getting warm
here are a couple of things to check. First look at the back inside wall of the freezer and see if it is getting coated with frost or snow. If yes, you probably have a problem with the defrost system usually the defrost heater burns out first. Once you replace the heaters, all the excess frost has to be melted off the cooling coils behind that wall. A hair dryer works well for this. Another thing t check is the fan motor that is back behind that same wall. If the fan stops for any reason--- you loose cooling on both sides.
5/9/2015 2:59:36 AM • KitchenAid... • Answered on May 09, 2015
2answers
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
4/25/2015 1:18:11 PM • KitchenAid... • Answered on Apr 25, 2015
We have water underneath our freezer and inside on the bottom shelf
You probably have a clogged drain line. Look for a drip pan at the bottom of the fridge; it should have a hose that drains into it. Thaw out the fridge like you did before, but this time use an air compressor, bicycle pump, or whatever and try to force air back up that hose to clear the clog.
2/19/2015 2:52:53 AM • KitchenAid... • Answered on Feb 19, 2015
How do i replace the small post that the crisper drawer rides on ?
you need a different site for this question this is a auto help site.
9/5/2014 5:09:04 PM • KitchenAid... • Answered on Sep 05, 2014
No power
Check the AC fuse. If it is blown, make sure that there should be any type of short circuit. Contact any service technician, to rectify the fault, before inserting such fuse. http://electronicshelponline.blogspot.com/
7/2/2014 4:53:23 AM • KitchenAid... • Answered on Jul 02, 2014
0answers
Change the water filter
I believe that this is an automatic warning to get you to replace the inline water filter located in the back of the refrigerator side up near the top. This sells water filters at 30+ dollars a pop. There is a procedure in your manual to replace the filter, but you could just reset the warning by holding the "filter reset button" for 3 seconds. that button is on the front door of the machine.
6/13/2014 1:34:57 PM • KitchenAid... • Answered on Jun 13, 2014
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
226 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
refrigerator stay cool but freezer works
  • Refrigerators
