20 Most Recent Frigidaire Affinity ATF7000E Front Load Washer Questions & Answers
Replace the door lock, takes about 10 mins. Just replaced mine. Ordered it from Amazon for less than 40.00. You take the top off and unscrew the lock from the front. Reach in and pull up, unplug old one, plug in new one. put new one back in the holes, screw it in tight. Put the top back on and your done. Don't forget to unplug it before you start.
Frigidaire... | Answered on Nov 24, 2019
Good Morning Friend, I am happy to assist you!
I understand your Electrolux washer is getting an error code E58. It could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Hope this helps! - Z
Frigidaire... | Answered on Jun 30, 2019
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Frigidaire... | Answered on Jun 02, 2019
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Frigidaire... | Answered on Apr 01, 2019
Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
Frigidaire... | Answered on Jan 03, 2019
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Frigidaire... | Answered on Oct 21, 2018
We have a code of efo
Frigidaire... | Answered on Jul 04, 2018
I just tried all manner of bending, pushing and prying the drum baffle. Can't get it to move. I'm thinking I need to break it to clean behind it then install a new drum baffle. At $49.35 plus tax and shipping I'll leave the coins there for now.
Frigidaire... | Answered on Mar 24, 2018
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Dec 28, 2017
please go tp the manufactures website and download the user manual its normally free and look in the trouble shooting section eric
Frigidaire... | Answered on Dec 27, 2017
It's the timer control, not the motor or filter. Try a different setting. You should also be able to find more information on the manufacturers website, along with a manual and possibly a diagram. Also You Tube is a good place to find out more on how to repair it.
Frigidaire... | Answered on Dec 03, 2017
You need to lean it back and remove the lower panel, you will have complete access to the water pump, disconnect hose clamps,remove and clean the rubber boot,disconnect electrical connector and 2 screws holding pump, Replace with new pump, before beginning take pictures to ensure proper installation
Frigidaire... | Answered on Nov 19, 2017
I would give it back and enact the warranty.
Frigidaire... | Answered on Nov 09, 2017
I understand that your Frigidaire Affinity dryer, model# ATF7000E, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home'sicon1.png circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Frigidaire... | Answered on Oct 20, 2017
I would be looking at drain pump for obstructions or pump may have failed
Frigidaire... | Answered on Sep 29, 2017
Frigidaire Affinity ATF7000E Front Load Washer Logo
1,529 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
fix error e23 toshiba washing machine
  • Washing Machines
