20 Most Recent
Anthology Solutions Yellow Machine P400T (250006001) 400 GB Network Hard Drive Questions & Answers
Yellow machine power out won't restart
You will have to get a disk recovery specialist to retrieve your data. The internal YellowBox system is Linux. The specialist will remove the disks and attach them to translation and recovery technology. It will cost money.
3/10/2014 2:52:28 PM •
Anthology...
Answered
on Mar 10, 2014
Yellow machine server.
Is it just the fault led, let the machine run for a while and see if it starts rebuilding the drives, if it is NEW and you have just installed the drives and never installed the software then you will get a fault I have the q400t which is the platnum version tho they still call it the p400t if you have just received the server then what u must do is power off the server plug in the netcable into one of the 8 lan ports run the install till it tell's you to turn it on then hit next then follow the instructions to setup the server
4/28/2010 12:00:55 AM •
Anthology...
Answered
on Apr 28, 2010
I have a yellow machine p400t and i need to give
Yes, it must be attached to the network
0. Install the yellow machine software on the PC
1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8.
2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears.
3.Click Edit.
4.Select Yes to Enable LAN Interface. Default: Yes (Enabled)
• If you select No, all other LAN option fields are blocked.
• If you disable the LAN Interface, the only access to the Yellow Machine appliance is
through the WAN port. Anthology Solutions does not recommend this configuration.
5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled)
6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address
• Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine
appliance connects to either a router that has DHCP service enabled or to a cable
modem. This setting makes the Yellow Machine appliance a DHCP client on your
network.
• Obtain IP Address from ADSL provider is greyed out.
• Choose Static IP Address if your network is locally defined and controlled and does not
use DHCP services. Type the IP address manually.
7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply.
8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
4/25/2010 5:39:52 PM •
Anthology...
Answered
on Apr 25, 2010
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
