20 Most Recent
Canon CLC-700 Copier Questions & Answers
Hello
E000–0061, 0071, 0081
1) Clear ‘E000’. Is ‘E000’
indicated immediately after the power
switch is turned on?
• Be sure to turn off the power
switch as soon as you have made the
check.
NO: Go to step 3.
Oil thermistor (TH5), Oil heater
thermistor (TH6; short circuit), DC controller PCB
2) Turn off the power switch, and
disconnect J6019 from J2209 on the
DC controller PCB. Measure the
resistance between a and b of the
following table in reference to the
detail code; is it 1 Kω?
Code a b
0061/0081 J6019-B5 J6019-B6
0071/0081 J6019-B10 J6019-B11
AC driver PCB
DC controller PCB
3) Replace the AC driver PCB. Is the
problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Error 000 switch power off
This is error in the fixing assembly, the fixing assembly is not getting hot at all. First try resetting the copier error. You do this by pressing the additional function key, then press the 2 & 8 keys at the same time and then the additional function key again. Press copier, then function, then CLEAR, then ERR then OK. This will clear the error from the copier's memory. Be sure to do nothing else within the service mode, you could really mess up some settings and cause more problems than you have now. Power cycle the copier and if the error comes back up then further fixing assembly then further repairs of the fixing assembly will be needed.
CLC 700
remove the lamp and check the continuity, the lamp may be burnt out, also check the lamp thermal fuse. Failing that, check the continuity of the lamp cable, it may be broken inside the sheathing. And failing that, replace the lamp regulator.
CAN any one help me for solve this problem. My
this is hardware technical problem if you can do that then follow the following thing or show it to service center.
changed the temperature and humity sensor, cleaned the door switch, and changed the primary corona .first check the primary corona assy. are the corona wires in the proper place on the the little end blocks in the proper groove. they should be in the groove thats closets to the grid wire the wire on top of the unit. Both ends of the corona wire, should be in that top groove, not one on top and the other on the bottom. )61 is a laser code, or should say potential voltage on the drum. Since it is not equal both sides, one side being darker, sounds like the corona wire is out of place.
Have a nice day and do not forget to rate please...!
Where on the cannon laser
There are two cleaning webs in the fuser unit. There is a upper and a lower web, there is also a counter that needs to be reset. The only solution is to replace the webs or flip them. Good Luck
My CLC-700 copier is showing 005 error. What does
A E005 means that the cleaning web for the fixing rollers have run out & there is also a counter that needs to be reset. There are two cleaning webs in the fuser unit there is a upper & lower web. They are white. The copier was calling for replace the web before it coded out. They clean the rollers off & oil's the rollers so the toner will not stick. You may find the parts on line, they are a bit tricky to replace.. Good Luck
Keeps giving error code 061
Hello sir; Did you recently replace new toner, if you did, please go back to check out does the door close right, otherwise you have to check the corona wire is broken?
Copier gets magenta toner on copies. Might get 1
There is probably an electrical fault related to the fuser unit or another high voltage component causing the machine to shut down. Since you have not mentioned the error it would be hard to ascertain exactly. Magenta on copies will be a sign that your machine needs cleaning and servicing by a trained technician - as there will be corona wires, cleaner units etc that need cleaning or replacing. The technician will probably find the cause of the shutting down whilst they are servicing it.
Problem in Color management settings for Canon CLC 900
thes machine are very old and outdated and will not function with up dated software but do a graduation adjust then do a calibarition with your firey that should get the colors back to canon spects, if you still hace the broblem then your software is not compatable
Error message
If prints all black,yuor problem in the optic section.Please check the exposure lamp,termofuse.If your problem to be charge or transfer/separator corona wire the copy is blank.If posible OPC drum cleaning blade damage or used toner rotative mehanism blocated.
Error code E061/0040
check and clean the Primary Charge unit or check all the door actuator check if there is damage .it couldbe the laser gate is not opening because the (door)actuator is broken
Copier won't stay on. Canon clc700
Most likely the either the scanning lamp or the fuser lamp circuit has on 'open' in it. Check the fuser lamps to make sure they are not burned out and make sure the thermal fuse it good.
Erorr code E061
Hi
Please my Canon Color Laser Copier is asking me for a code, when i put it on it shows E350 on the table. sir what should i do.
