20 Most Recent Ricoh Aficio 250 Copier Questions & Answers
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Ricoh Aficio 250... | Answered on Sep 11, 2017
exposure lamp ,lamp stabilizer board . dirty white plate .dirty optics.SBU board .CCD
Ricoh Aficio 250... | Answered on Sep 12, 2015
Try getting into service mode and see if you can reset the user passwords by turning them off in the settings.
Do you know how to get into service mode?
Ricoh Aficio 250... | Answered on Jan 06, 2015
my dear toner botle change
Ricoh Aficio 250... | Answered on Jun 10, 2014
You copier does not use ink, but toner. And because the "ink" detector is on, it could be the toner cartridge is empty.
Try to remove the toner cartridge and shake it firmly. than replace it. This could help for a few copies, but you must order new toner, if the sheets of paper keep coming up blank.
what is the problem ricoh j001
Ricoh Aficio 250... | Answered on Oct 05, 2013
ricoh mpc3500 paper jam j001 which sensor ,no have inside paper
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Ricoh Aficio 250... | Answered on Sep 14, 2012
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Ricoh Aficio 250... | Answered on Aug 23, 2012
Ricoh Aficio 250 Copier Logo
109 questions posted
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
error code j001 shows up
  • Office Equipment & Supplies
