20 Most Recent Sansui DTV3200 32" TV Questions & Answers
Is there any way to get into menu to change from "ant" to "cable" without remote? TV does not have original remote and universal remotes will not access menu options.
Hold volume -/+ few seconds, menu will appear. Navigate up/down menu with channel buttons, page change with volume buttons.
4/19/2015 3:42:29 AM • Sansui DTV3200... • Answered on Apr 19, 2015
0answers
0answers
Can't get one local channel when hooked up to T.V. antenna
Take a gun and shoot your self.
2/10/2013 2:14:03 PM • Sansui DTV3200... • Answered on Feb 10, 2013
Sansui sv-4600LCD no color black and white only
Check its color settings, and antenna orientation.
11/5/2012 12:13:46 PM • Sansui DTV3200... • Answered on Nov 05, 2012
How to program channels for Sansui TV with Comcast remote
You should have received the codes and directions for the tv with your remote. I just got a new remote and it came with the codes in the manual as well as how to program your tv and other devices.
10/30/2012 7:35:17 AM • Sansui DTV3200... • Answered on Oct 30, 2012
How to unlock childs security?
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Instructions
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View. Lock the controls to activate the changes using item six on the "Parental Controls" menu
6/29/2012 1:45:49 AM • Sansui DTV3200... • Answered on Jun 29, 2012
Television was alright when it was cut off. Next
Tv is missing a color green,recheck ur tv Ant.hole coaxial cable input.Take the cable apart and reconnect to the Ant.hole again see if this help?Not make a fist with ur hand bang on the tv back cover frame see if the color green come back or flashes?Yes,than the tv CRT video board that is connected to the CRT- picture tube have cold soldering joints around it video board connections sockets,require resoldering the socket joints connections between the CRT video board and CRT tube connections socket.U have tools like a soldering iron,a roll of solders and can do basic soldering work?Yes,this problems just require resoldering that it.
6/10/2011 5:35:19 PM • Sansui DTV3200... • Answered on Jun 10, 2011
0answers
My sansui tv sound comes
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps in solving the problem....Take care.
9/5/2010 8:44:52 PM • Sansui DTV3200... • Answered on Sep 05, 2010
Lost Remote Control
Hi
Thanks for using FixYa. Please post a comment with the manufacturers name and model no# of your remote so that I can assist you further.
Thanks
Rylee
7/22/2010 2:29:33 PM • Sansui DTV3200... • Answered on Jul 22, 2010
How to program a universal remote for the Sansui
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
7/14/2010 8:36:34 AM • Sansui DTV3200... • Answered on Jul 14, 2010
I have a Sansui TV model DTV3200. Vertical foldback
fold back means u have to check power supply to v/ ic 25v. if it is ok,,, u have tochange all capacitors in vrtical section,, sometimes feed back resistors may be fauty,,check them also
3/19/2010 6:48:00 AM • Sansui DTV3200... • Answered on Mar 19, 2010
I can't get my TV on channel av.
press menu on ur tv and look for input select if u mess around with ur tv enoughyou will find what ur looking 4 all tvs have a way its just labled diffent
12/15/2009 12:58:56 AM • Sansui DTV3200... • Answered on Dec 15, 2009
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
7/31/2009 6:18:24 PM • Sansui DTV3200... • Answered on Jul 31, 2009
Tv will power on sound works fine..but no
maybe one of your rgb amplifier is loose or deffective
7/31/2009 2:19:55 AM • Sansui DTV3200... • Answered on Jul 31, 2009
Sansui DTV3200 32" TV Logo
43 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
up down channel selection not working
  • Televison & Video
