Akai PT46DL10 46" HDTV-Ready... • Uploaded on Oct 08, 2013
If there is no power then it is possible that the SMPS has failed. check link at the bottom.
Also sometimes dry soldering is a common fault which can be checked and corrected by you assuming that there is no component failure . There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Check that the power cord is securely plugged into the power outlet.
Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
Contact akai Support if Steps 1 to 3 do not solve your problem. Only a trained service technician should attempt to fix the power problem with your television
130 questions posted
255 Questions
269 Questions
227 Questions
221 Questions
201 Questions
