20 Most Recent Mitsubishi WD-52531 Television Questions & Answers
I would lean towards the main board
Mitsubishi... | Answered on Nov 27, 2017
go to www.tvassist.co.uk if its not listed they will almost certainly still stock it call them and ask them to list it and they will
Mitsubishi... | Answered on Nov 18, 2013
this man eddie is right.^ it helped my tv!!!
Mitsubishi... | Answered on Nov 11, 2013
Try taking it in to be fixed if you have a warranty, otherwise, you might need to buy a new tv.
Mitsubishi... | Answered on Aug 28, 2013
Try unplugging it and then plugging it back in.
Lamp life for this model is 2 years or 2000 hours, less if a non Mitsubishi lamp is used, sounds like a bad lamp.
Mitsubishi... | Answered on Dec 22, 2012
Lamp is bad--customer replaceable--Google the model number with the word "lamp" to locate a replacement---get one with the Mitsubishi name on it
Mitsubishi... | Answered on Apr 26, 2012
From what I researched, after changin a bulb on these TV's some capacitors fail and "pop" on the DM board, You will have to take it apart and re-cap the caps on the DM board 1000uf 10v (4 - 7 of them). This solves the problem in most cases
Mitsubishi... | Answered on Apr 24, 2012
hint: the two pins the lamp plugs onto go directly to the ballast which is really a power supply for the lamp.
not clear from all you have said if ballast is the problem===these sets had a lot of issues; anything, even too much dust on the fans inside will shut it down...........
Mitsubishi... | Answered on Mar 29, 2012
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
i hope this will help to solve the problem...
Mitsubishi... | Answered on Aug 06, 2011
You may have not plugged the lamp in fully or have not put the lamp door back properly. If you have done this properly and have the blinking problem then you are likely to have a bad ballast. This ballast supplies the voltage to light up the lamp. But first look on the front of the set for a small push button that says "system restore/reset". Use a ball point pen to press.
Mitsubishi... | Answered on Jun 30, 2011
Did you try the soft reset?
With the set on and using the Mitsubishi remote: Menu, 1,2,3 and Enter.
SD TECH
Mitsubishi... | Answered on Jun 03, 2011
Did you take the lamp out and look at it to see if it is shattered inside the bulb?
Mitsubishi... | Answered on May 20, 2011
Mitsubishi WD-52531 Television Logo
53 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
hered pop sound now tv wont work
  • Televison & Video
