20 Most Recent
Sennheiser HD 202 Consumer Headphones Questions & Answers
The left headphone is not
The most common caused of this symptom is the bad
solder joints in the speaker of the affected parts. If you can take it apart
check if one of the wire has it then resolder.
Another is the open internal wire in the cable
of the headseat. You may confirm it using a continuity check with a multimeter.
Place the earphone to your ear, upon testing the end of the headset plug you
will hear a scratching sound...
To confirm where the fault came from insert
another headset to your unit. If the symptom does not appear in the new
headset, above was a caused of the symptoms.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
I have Seinheiser HD 202
The fault is in the cable: you will have to dismantle the left speaker housing and start cutting from the cable until the break is removed then solder it back to the speaker - use an multimeter to check the continuity of the wires.
Right side started cutting out and now is out
It's a common problem for the headphones: internal cut of the wire, usually near the end, either at the headphones' end, or at the 3.5mm or 6.3mm jack end. Some headphones have detachable cable (can be easily disconected from headphones side) so it's easy to replace it. In your case (HD202) I think it's not detachable, so you have to get them at a technician or at the service center in order to replace the cable or cut and recconnect it a little bit after the cutting point.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
The right headphone is not playing music
Most faults in headphones are caused by either a broken cable or a faulty plug. Try moving the cable or plug around in various places to see if it come back on, look for wear or a break too! If you find it you will have to replace the plug or cable. The only other cause is a faulty speaker, but they are not common.
Sennheiser RS 175 TV headset has green lit power light blinks on and off. And headset doesnt have any volume. Help!
If your Sennheiser RS 175 TV headset has a green lit power light that blinks on and off and doesn't have any volume, here are some troubleshooting steps you can try:
- Check the batteries: Ensure that the batteries are charged and inserted correctly into the headset. You may also want to try replacing the batteries with fresh ones.
- Check the audio source: Make sure that the audio source is turned on and the volume is turned up. You may also want to try connecting the headset to a different audio source to see if the problem is with the source.
- Check the audio cable: If you are using an audio cable to connect the headset to the audio source, make sure that it is plugged in securely at both ends.
- Reset the headset: Try resetting the headset by turning it off, unplugging the transmitter from the power source, waiting for a few minutes, and then plugging the transmitter back in and turning the headset on again.
- Check for interference: Make sure that the transmitter and headset are not too far apart or obstructed by walls or other objects. Also, ensure that there are no other devices nearby that may be causing interference.
If none of these troubleshooting steps work, you may need to contact Sennheiser customer support or take the headset in for repair.
HOW DO I CONNECT MY SENNHEISER RS 120 HEADPHONES TO MY LG UHD TV MODEL 55UK63
Hello Mike, your LG TV, does not have a headphone output, it only has optical fiber audio output
the options that I suggest are,
1) Connect the optical fiber output of the LG, to an AV receiver, that has said input and place the headphones in this equipment,
2) Buy an optical fiber to audio converter by RCA L and R and this is connected to a headphone amplifier
I send you links to the products that are sold in my country
I hope you solve your concern
Greetings Franco Dosil
This is the headphone amplifier
This is the optical fiber to audio converter by RCA L and R
Hola Mike, tu TV LG, no cuenta con salida de auriculares, solamente tiene salida de audio por fibra ?ptica
las opciones que te sugiero son,
1) Conectar la salida de fibra ?ptica del LG, a un receptor AV, que cuente con dicha entrada y colocar los auriculares en este equipo,
2) Comprar un conversor de fibra ?ptica a audio por RCA L y R y este conectarlo a un amplificador para auriculares
Te env?o links de los productos que se venden en mi pa?s
Espero logres resolver tu inquietud
Saludos Franco Dosil
este es el amplificador de auriculares
Este es el conversor de fibra ?ptica a audio por RCA L y R
Este es el amplificador de auriculares
https://articulo.mercadolibre.com.ar/MLA-784156450-behringer-ma400-ultra-compact-monitor-auricular-amplificador-_JM
This is the fiber optic to analog audio converter
https://articulo.mercadolibre.com.ar/MLA-707192478-convertidor-audio-digital-toslink-optico-coaxial-a-rca-nuevo-_JM
SENNHEISER EW100 G2 wireless microphone RECEIVER with lcd flashing all the time. Not functional.
Hi Edgar, it is important that the receiver works, because there is a dialogue between the transmitter and the receiver to confirm that they are on the same frequency, that is why the transmitter is blinking, you should repair the receiver and look for the frequency or channel that the transmitter is found and it will stop flashing
Hola Edgar, es importante que el receptor funcione, porque hay un dialogo entre el transmisor y el receptor para confirmar que est?n en la misma frecuencia, por eso es que el transmisor esta titilando, deber?as reparar el receptor y as? buscar la frecuencia o canal que se encuentra el transmisor y este dejara de titilar
