20 Most Recent GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw Questions & Answers
2answers
I have a10 channel DVMR -10eZT. When I tried to
check charged, in this trouble the current is 12V @ 7 amp but the chargen not is provides sufficient current. change the source for other in equal condicions and test.
4/20/2011 7:10:29 AM • GE Interlogix... • Answered on Apr 20, 2011
2answers
No video feed. just a blinking DVR on all screens
What type of cable(s) are you using for the video signal?
Thanks!
11/18/2010 4:25:16 PM • GE Interlogix... • Answered on Nov 18, 2010
I have a ge dvr
You are going to need to contact the manufacturer to have them assist you in bypassing and then resetting that second security code. There is no simple way to just get around it... it is hard coded now to memory inside the unit. You would need to take apart the whole system and take out all the internal batteries, but it is very difficult and delicate work. Then leave them out and leave it unplugged for at least an hour, that should erase the memory and all stored passcodes, but it is not easy at all.
Give GE Security a call to get assistance with this from a live person. Their number is 1-888-437-3287
10/10/2010 2:57:10 PM • GE Interlogix... • Answered on Oct 10, 2010
2answers
Need manual to understand how to access the video
Request a copy from point of purchase. That is an expensive unit.
10/20/2009 9:35:36 PM • GE Interlogix... • Answered on Oct 20, 2009
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
8/30/2009 7:02:40 PM • GE Interlogix... • Answered on Aug 30, 2009
0answers
User manual
Be the first to answer 5/13/2009 12:57:26 AM • GE Interlogix... • Posted on May 13, 2009Be the first to answer
Unable to connect remotely to dvr unit
I'm presuming you are using Internet Explorer. You may need to change your browser's security settings to solve this problem.
Using Internet Explorer, click on TOOLS, Internet Options, Security, Local Intranet, then move your slider all the way down to Low and click Apply.
3/18/2009 7:39:27 PM • GE Interlogix... • Answered on Mar 18, 2009
Motion detector is not working for GE INTERLOGICX 60-806-95R
All wireless security motions have a 3 min delay built into them. This means that whether the alarm is set or not when the motion detector picks up motion it shuts down for 3 min and will not pick up motion. This is done to conserve battery power. So I always advise customers to arm the system and stay away from the motion for 3 min total. example: 60 sec to arm system + 2min wait time. then try to trigger motion. If this does not help and assuming batteries are good, you'll need to replace motion. Good luck. This may help https://al.ly/vR54zP
12/15/2019 10:15:53 PM • GE Home Security • Answered on Dec 15, 2019
Locked In! GE SImon XT Doors & Windows - not taking code(s). Code(s) work to set date/time, but when trying to disarm "doors & windows - no entry" condition, no code works. No characters display.
I would start by power cycling your system. Remove the battery & power. After waiting 10 minutes or so reconnect the battery and then power. Other than that you need to be a bit more specific with your issues.
5/3/2019 7:01:09 PM • GE Home Security • Answered on May 03, 2019
Ge security system says service and the red fire light is on but there is no fire.
Try disarming system twice to get the fire zone to reset. If that doesn't work, try to downpower the entire system, including back up battery then re-power the system with the back up battery first.
10/24/2018 1:30:36 PM • GE Home Security • Answered on Oct 24, 2018
How reset dvsr admin password to default settings
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://www.novisec.nl/cms/component/option,com_docman/task,doc_view/gid,67/
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 17 of the ONLINE USER'S MANUAL for detailed instructions on how to reset the unit to default settings. Basically it says:
Push the MENU button, select admin and enter 3477 for the password, then press OK to confirm.
Use the arrow keys to navigate to UTILITIES, then press ENTER.
Then navigate to RESTOREPARA and press ENTER.
Then select OK to confirm and the system will automatically reboot.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
10/8/2018 12:05:04 PM • GE Home Security • Answered on Oct 08, 2018
GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw Logo
19 questions posted
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
View Most Popular
GE Home Security
  • GE Home Security
Most Popular Question
a10 channel dvmr 10ezt when tried
  • Home Security
