This is Gateway Support, and Support Documents for the Gateway GT5428 Desktop PC,
http://support.gateway.com/s/pc/R/1009466/1009466nv.shtmlOn this page left-click on Components.
Scroll down the page to the heading - Motherboards
Left-click on -
4006158R - Intel (Coryville) 945G Motherboard
Now Left-click on - Product Views
Lastly left-click on -
O - Front Panel Connector
This shows you a photo of the Front Panel header on the motherboard.
A connection on a motherboard is referred to as a Header.
The Front Panel of your computer is the plastic part where the Power On button is.
The Front Panel header on the motherboard is where the wires from the Front Panel connect to.
The above is not to offend you, or insult your intelligence. Just wanted to give you the exact names of the parts you'll be handling.
Looking at your motherboard with the Processor to the top, and the Ram slots to the right, the Front panel header is located in the very bottom right corner.
Looking at the Front Panel header on the motherboard, you will note the different colors.
There are also Pins that stick up out of the Front Panel header.
Every 2 pins is grouped into one color.
The Front Panel header is located parallel to the outside edge of the motherboard.
There are 2 rows of pins.
One row across the top of 5 pins.
One row across the bottom of 5 pins.
The pins are numbered, as well as grouped into colors.
Starting at the Right side, going towards the Left, on the Top row;
Pins 1, 3, 5, 7, and 9
Starting at the Right side, going towards the Left, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
Pins 1 and 3 ( Yellow ) are for the Harddrive Activity LED.
The light in the front panel that flashes when the harddrive is actively being used.
Pins 2 and 4 ( Green ) are for the Power On LED.
The light in the front of the computer that shows when the computer is on.
Pins 5 and 7 ( Blue ) are for the Reset switch.
The Reset button on the front of the computer, IF, the computer came with one.
Pins 6 and 8 ( Red ) are for the Power On switch.
The Power On button on the front of the computer.
Pin 9 (Black) is for the +5 Volt power
Pin 10 is not used. (Not connected)
The reason I took you the long way, and did not just provide a link to the Front Panel header, is in case you need more information about your computer.
This way you'll have it.
