20 Most Recent
SKYPE SPP-S2730 Questions & Answers
When i call someone on
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
hope this helps
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this was helpful don't forget to vote
Delet messages on skype
On the message when ur move ur mouse to message right side three dots will be shown on vertical click on that there it will show remove option
Download IOS 9
So, what is the question? Go to the App Store and download it.
My skype does not function
What part of it doesn't work? Give me more information about your situation and I should be able to assist you.
Unable to recover my Skype password. any one can help me please?
All those types of places usually have a button that says forgot password. Press that and see how they will let you reset it! But if you don't have access to say for example the email you used to start it and they can reset it via sending you an email then click the link within to reset, you won't be able to. Various sites even can send you a code via text message etc....there is lots of diff ways our fave sites can reset our passwords we forgot. But a few are very crazy and cause you a headache that just making a new acct is easier & safer! If you can reset it please post here for the next person who may have the same prob you are dealing with now! Best of luck!
How To Fix Skype Disk I/O Error?
you must complete a full disk check(your disk has bad blocks OR its FULL! ouch!). Open my_computer, select and right click the os disk and choose properties, click tools, click check disk. schedule a full test restart and let the test run to completion(takes at least 5-10 mins) then try again. Could need a skype re-install.
How to fix Skype Microphone Problems and Improve Call Quality?
There are three factors with the quality of the calls in Skype.
1. How fast is the upload and download speed of the internet service being used (and also if many users are sharing it).
2. The quality of the headset/microphone and speakers being used.
3. The Skype software needs to be up to date and also the computer that it is installed on has sufficient RAM, CPU allocation for it. Best to test after restarting the computer.
With regards to the internet bandwidth shown on the 1st factor, it goes both ways from the caller to the receiver of the call. If any one of the two (or more if it is a conference call) then you will experience difference in quality of the call.
Here is a link where you can find information on how you can test the call quality for Skype.
How do test my sound is working in Skype make an Echo test call Skype...
