20 Most Recent LG LMV1630ST Microwave Oven Questions & Answers
2answers
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
10/24/2019 6:22:48 AM • LG LMV1630ST... • Answered on Oct 24, 2019
2answers
Some panel buttons are not working on my LG LMV1630ST
The problem is in the keypad control board and must be replaced, I would consider cost before you allow the go ahead.
4/6/2019 2:18:03 AM • LG LMV1630ST... • Answered on Apr 06, 2019
Key pad dont work
replace transformer on pc board
9/27/2018 8:58:53 PM • LG LMV1630ST... • Answered on Sep 27, 2018
Remove door on LG LMV 1680st microwave
I am sure, this YouTube video https://www.youtube.com/watch?v=nIdT4kS3noY will be helpful.Admin: http://microwaveoven.co.in/
10/28/2017 6:12:08 AM • LG LMV1630ST... • Answered on Oct 28, 2017
Where is the LG LMV1630ST fuse located and what does it look like
https://youtu.be/fUIQ0u01SyY
3/29/2015 10:32:12 AM • LG LMV1630ST... • Answered on Mar 29, 2015
Nothing on keypad for my microwave works
Be very careful around microwaves they have very high voltage inside them that can be deadly. As for the control panel its very common for grease and oil to get behind the plastic film of the control panel, once it does the buttons will stop working since the grease insulates the contacts. Unplug it from the power, let it sit for 60 minutes to make sure all power from the high voltage caps has dissipated. Get access to the back of the control panel. You will probably have to peel back the control plastic on the front to get behind it. One behind clean all the buttons and contact areas. Reassemble, and it should work.
8/11/2014 3:48:30 AM • LG LMV1630ST... • Answered on Aug 11, 2014
How do I replace the door?
The door comes in parts not the whole door. All you have to do is remove the plastic liner around the glass and you can get to the screws that hold the door in place. Go to sears web site and you can order the parts thru them they are pretty good about getting the parts for you
6/10/2014 7:14:07 AM • LG LMV1630ST... • Answered on Jun 10, 2014
Microwave won't heat what do I do
disconnect from power,then remove the cover and test the fuse and the grounding diode for failure then replace but if still not heating then replace the magnetron.
6/7/2014 11:38:46 PM • LG LMV1630ST... • Answered on Jun 07, 2014
Lg microwave oven... always got fused busted.. one by one i tried to trace the main problem i disconnect hv. diode. hv cap and the transformer. if i start it , it works ok but if i install back tra
Change Bridge Rectifier Diode And Capacitor Without Test by Meter,Some Time it will licks,Check All Connected Parts,And Last Is Transformer
5/29/2014 7:39:07 AM • LG LMV1630ST... • Answered on May 29, 2014
0answers
LG LMV1630ST Microwave Oven Logo
119 questions posted
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
replace door
  • Microwave Ovens
