20 Most Recent
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer Questions & Answers
The indicator panel is flashing
You will need to gain access to the drain motor filter. Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
The rubber seal at the front of the machine has
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use
powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door
open to allow it to dry. .
Classixx 5 bosch washing machine stalls/judders at start of cycle
Plug off the power cord from the wall mains. I give you several alternatives, sort out thru the easiest: Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. The spin has a lot to do with worn motor brushes. Manufactures want you to dump machines and buy; it helps them all. Not you - you shell out bucks.If you have already cleaned out your filter, which is usually just under the tub (be prepared for a lot of water; and disconnect from the wall power socket), your washer still may not spin. So look into next para below. The tech sheet is usually taped to the body of the washer inside somewhere.Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. Thespin has a lot to do with worn motor brushes. Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been overloaded and shut itself off.There is a big connector located at the motor - giving power to the motor (located under the tub) to the right side, could be loose. Disconnect the connector and refit to make sure it is tight. Before refitting the back, etc, try the spin alone; if it works you are done. Click if helped pl, at my solution. I am doing this for the enviro. (& you)
My Bosch Nexxt 800 series washer no longer
Hi
You'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
How to use rinse hold
I am under the impression that you select 'rinse hold' and it will do exactly that if you want it to ;-0)
However I think that a manual would probably assist you even more than my comment!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
