20 Most Recent
Nespresso Essenza C100 Espresso Machine/Coffee Maker Questions & Answers
Nespresso no power
hi you should be able to relocate 2 thermal safety on the boiler check these two with continuity meter start here first if all is well get back to me
1/12/2021 10:50:38 AM •
Nespresso...
Answered
on Jan 12, 2021
Does anyone know how to pull apart a Nespresso coffee maker ?
Most expresso coffee makers can be taken apart manually.
Start removing screws, nuts, etc. Take a picture every so often so you know how to put it back together.
See the DeLonghi website to get eerie product manuals. (delonghi.com). Search harder for repair parts and you often can get the sequence of how the parts assemble.
You are right, cleaning the jets is the biggest problem area.
1/23/2018 6:01:07 AM •
Nespresso...
Answered
on Jan 23, 2018
Will not dispense the water into the cup when the
I have had this issue. First, check to make sure water tank is filled and correctly in place? Try descaling it; a kit came with coffee maker. (It just removes hard water build up, it may be blocking your water flow.)
If that is not the issue, pull the tray where the used pods are dropped -Is it wet? Like the coffee is pouring into this tray rather than in your cup? If so, I have removed round silver plastic piece from around coffee spout,(gentle -do not crack it) then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! If the POD tray is not wet, I would tell you not that most likely your machine is not clogged by grounds, so you may not want to take snout apart. I hope this helps.
11/23/2014 8:09:24 AM •
Nespresso...
Answered
on Nov 23, 2014
