20 Most Recent Toshiba e-Studio 232 Black and White Copier Questions & Answers
toshiba estudio 232 errr ca20 wt problems?
Toshiba e-Studio... | Answered on Jan 13, 2020
cartage dispenser wheel might have broken,try with different cartage .
Toshiba e-Studio... | Answered on May 20, 2019
What email client are you using? THe scan app is not able to access the default mail application or the application is wrong.
Toshiba e-Studio... | Answered on Mar 29, 2019
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Toshiba e-Studio... | Answered on Feb 16, 2019
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Toshiba e-Studio... | Answered on Dec 02, 2018
go to user you will find.
Toshiba e-Studio... | Answered on Aug 25, 2018
C010 indicates main motor problem...
U need to open up the back cover, perform output test to check whether the main motor is working. 03-101(ON)/151(OFF)
Toshiba e-Studio... | Answered on Jul 17, 2018
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Toshiba e-Studio... | Answered on Jan 08, 2018
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Toshiba e-Studio... | Answered on Oct 28, 2017
You have a corrupted hdd promblem on you toshiba. You should find another hdd and the firmware and make them using usb stick
Toshiba e-Studio... | Answered on Oct 10, 2017
you will never get it if you do not purchase it and pay first , FIXYA can not assist you
Toshiba e-Studio... | Answered on Oct 07, 2017
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Toshiba e-Studio... | Answered on Sep 27, 2017
Paper not reaching/pass exit sensor, check the exit sensor and actuator (easily break)
Toshiba e-Studio... | Answered on Sep 10, 2017
No need to setup, plug n play...
Toshiba e-Studio... | Answered on Aug 09, 2017
Switch on while pressing '*13'
Toshiba e-Studio... | Answered on Jun 07, 2017
Try changing Hard disk.
Toshiba e-Studio... | Answered on Apr 13, 2017
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Toshiba e-Studio... | Answered on Aug 23, 2016
How to reset Toshiba E-Studio 233
Toshiba e-Studio... | Answered on Aug 22, 2016
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
Toshiba e-Studio 232 Black and White Copier Logo
367 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
toshiba e 232 code c430 not
  • Office Equipment & Supplies
