20 Most Recent
Canon imageRUNNER 1023iF Black and White Copier Questions & Answers
How do I reset my Canon 1023If back to the default
Reset your copier to default settings:
Go to Service Mode by pressing Additional Function + 2 + 8 (Simultaneously) then Press Additional Function again. Go to CLEAR and Select ALL.
Please be reminded that this will erase ALL data on your printer.
Hope this helps.
11/19/2021 10:06:40 AM •
Canon...
Answered
on Nov 19, 2021
I am getting a download standby message
Short two pins at JP141 on PCB with screwdiver or paperclip. Should be lower left of image processor PCB. Have to remove back cover, short or connect two pins, then power on machine this will reset.
10/26/2021 5:39:28 PM •
Canon...
Answered
on Oct 26, 2021
DOWNLOAD STANDBY ERROR
I believe this is just a glitch in the copier. You need to do a printer reset. I do believe this will get rid of all the internal information of the copier -addresses, network setting, etc. Hopefully someone printed out the data lists after the intial install. Press the additional function key, 2 key, 8 key, additional function key. Press the left arrow key, below the display, until #CLEAR comes up. Press OK, then left arrow until ALL. Press OK. Then wait and copier will cycle. Hopefully all is well then. You will ahve to intall all, settings as a new install. Good luck.
4/24/2018 12:20:26 PM •
Canon...
Answered
on Apr 24, 2018
Error E 354
Description
System error
Remedy
Contact to the sales companies.
1/9/2018 6:57:54 PM •
Canon...
Answered
on Jan 09, 2018
The problem issue the photocopy machine canon
The procedure for stop copy is you press red and then machine ask you left or right pointer for yes or no.Is thath way did you stop copying?
If yes it may be machine system problem.
2/25/2015 3:40:43 PM •
Canon...
Answered
on Feb 25, 2015
Uneven copy quality- Canon Copier
If the toner isnt burned on paper it means that you have to change fixing roller bushings and fixing roller.
Because you have uneven pressure between fixing and press roller
7/29/2014 6:35:30 AM •
Canon...
Answered
on Jul 29, 2014
Pls my copier canon IR
Try this... Turn ON the power while pressing and holding keys 1 and 9... If this doesn't solve the problem, contact your nearest Canon service center for upgrade of your machine firmware...
3/28/2014 11:41:51 AM •
Canon...
Answered
on Mar 28, 2014
