20 Most Recent West Bend 84496 6-Quart Slow Cooker Questions & Answers
5answers
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
11/13/2017 5:08:13 PM • West Bend 84496... • Answered on Nov 13, 2017
0answers
2answers
I need a new handle for my West Bend slow cooker
you will have to replace the whole cremaric pot you can find it here
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2953&secid=54&linkon=subcategory&linkid=31
10/31/2015 5:56:38 PM • West Bend 84496... • Answered on Oct 31, 2015
0answers
2answers
Lid doesn't fit tight
put aluminum foil around lid and press onto pot this will help it make tight fit
12/10/2012 7:25:29 AM • West Bend 84496... • Answered on Dec 10, 2012
West Bend Slow Cooker error
if you put something frozen or cold in it and let set for awhile without turning on then you must take it out let unit get room temp. then start it . E01 error means the unit is too cold to start.
8/22/2012 3:13:46 AM • West Bend 84496... • Answered on Aug 22, 2012
West bend slow cooker model
NO, these stoneware inserts are not meant for the high dry heat of conventional ovens. It will crack in the oven...use only in the crockpot!
8/7/2011 4:53:40 PM • West Bend 84496... • Answered on Aug 07, 2011
Is there a toll free number in Canada for west
Contact information for Canadian Service Centers for West bend products can be found here:
http://focusdev.c3chicago.com/finditem.cfm?itemid=3904
You might also try the web inquiry form at:
http://www.westbend.com/finditem.cfm?itemid=3230
Your Instruction Manual and available parts can be found here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=3063&secid=87&linkon=subcategory&linkid=104
5/17/2011 2:51:25 AM • West Bend 84496... • Answered on May 17, 2011
2answers
LID
https://www.focuselectrics.com
Go to productsm find yours and select it. There will be a number to select for the parts list. A New lid with knob is under $6 + Shipping
4/17/2011 5:54:48 PM • West Bend 84496... • Answered on Apr 17, 2011
Good evening! Can the ceramic insert
seems rather plausible, however wouldn't it be best to visit the company website - and -- or download an owners manual for this particular unit just to be certain?
Best regards
Ck
3/8/2011 11:00:33 PM • West Bend 84496... • Answered on Mar 08, 2011
I need a new pot
call west bend customer service and they will be able to send you another i thought they glass lined
2/10/2011 11:56:55 PM • West Bend 84496... • Answered on Feb 10, 2011
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
2/8/2011 3:55:36 AM • West Bend 84496... • Answered on Feb 08, 2011
I need a new lid
You can try to call 866-290-1851
The only part they have for your pot is the crock...
http://www.westbend.com/finditem.cfm?itemid=3063
heatman101
2/8/2011 2:12:50 AM • West Bend 84496... • Answered on Feb 08, 2011
DON'T KNOW HOW TO START
You can download the manual here.
Please rate my reply - thanks!
1/20/2011 7:31:48 PM • West Bend 84496... • Answered on Jan 20, 2011
I have the oval west
West Bend no longer carries the replacement lid. The only part that they carry for this model is the crock itself.
Your best bet is to keep an eye on eBay for the item. Often there are parts available. I have just looked using your model number, however, it could be the the lid is not marked, which makes the task a little harder. You can however scan through "oval crockpot lids" and see if you can find your lid. I have just looked that way also and do not see anything that would be your lid. another good source for this type of part is a secondhand store. Good luck! Thank you for using FixYa and please rate this answer.
12/24/2010 6:23:05 PM • West Bend 84496... • Answered on Dec 24, 2010
I dont know what buttons on the front to push to
no it is good
12/7/2010 3:04:09 PM • West Bend 84496... • Answered on Dec 07, 2010
West Bend 84496 6-Quart Slow Cooker Logo
57 questions posted
Top West Bend Crock Pots & Slow Cookers Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a West Bend Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
View Most Popular
  • West Bend Crock Pots & Slow Cookers
Most Popular Question
when turn get e01
  • Crock Pots & Slow Cookers
