20 Most Recent Panasonic PT-56DLX76 Television Questions & Answers
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button if it does not work the first time....try holding down the tv off button a bit longer
1/3/2015 8:54:20 AM • Panasonic... • Answered on Jan 03, 2015
0answers
My panasonic PT-56DLX76-K TV just shut off and now when I turn it on the power indiction just conitnually flashes green but the TV won't turn on. Any ideas?
Check lamp door and make sure it's secure for the safety switch to be engaged.
11/21/2011 6:09:19 AM • Panasonic... • Answered on Nov 21, 2011
I have a DLP tv,
One of your color guns (Red, Green and Blue), have quit working correctly. It perhaps is the blue one and the red gun operating at it's usual level is washing out any other. You need all three guns to get the mix of colors, so repair is in order.
4/16/2011 11:52:30 PM • Panasonic... • Answered on Apr 16, 2011
I have a Panasonic DLP, PT-56DLX76, and when I
Hi.
The high pitched noise is a capacitor or an IC that is failing. EPCOS is an electronic manufacturer. If the part is a capacitor and its melting, that is the reason for the noise. The symptoms are those of a defective PSU. Power supply will be the first part to be tested. If you have already removed the back of the TV, disconnect power and look for bulged or burnt capacitors in PSU board. Do not touch them, as capacitors can release discharge even after disconnecting power cord.
Parts are mostly not in stock. Here the part seller.
Service manual available here:Click here to start download..
If that does not work, use this link (same upload): http://www.mediafire.com/?bsiideszwey9k8b
Regards.
Ginko.
2/24/2011 5:05:32 PM • Panasonic... • Answered on Feb 24, 2011
Lamp flashes red and tv
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
1/21/2011 3:13:42 PM • Panasonic... • Answered on Jan 21, 2011
Pt-56dlx76 panasonic light flashes red 3 times. I
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
12/16/2010 5:13:46 AM • Panasonic... • Answered on Dec 16, 2010
Resetting the timer for the
stephanie286,
Here is the porcedure:
The procedure is a little bit tricky so that you do not do it accidentally.
1. Turn on the television.
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
If it works you will see a message saying the lamp timer was reset to 0 and the indicator will turn off.
Thanks for using FixYa and for the great rating.
hardrocko
11/30/2010 1:57:43 AM • Panasonic... • Answered on Nov 30, 2010
PT-56DLX76 Television: The tv turns on for a couple minutes, then turns o...
Contact Panasonic Tech support..tell them series of flashes
5/20/2010 4:53:53 PM • Panasonic... • Answered on May 20, 2010
When i try to turn
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
By looking at the above chart, you would know, what's the Fault is.
You need to Call tech to get this Fixed. If you have TV repair Experience and would be able to take all the precautions, i would be more than happy to assist you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/23/2010 3:20:14 PM • Panasonic... • Answered on Jan 23, 2010
Panasonic hds700tds playing audio no videos
  1. Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
  2. Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
  3. Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
  4. Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
  5. Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
  6. Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
  7. Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
  8. Hope this helps
4/9/2024 11:43:10 PM • Panasonic... • Answered on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
  1. Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
  2. Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
  3. Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
  4. Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
  5. Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM • Panasonic... • Answered on Apr 09, 2024
I'm about to lose my mind trying to find the + on a Panasonic remote! Can anyone tell me how to find it? The + is part of my router code to connect my tv to the internet.
Unfortunately there isn't one. The workaround is to change the Router Password or SSID to remove the plus + for something else.
need to input the plus sign for wifipassword XXXXX my ...
JustAnswer https://www.justanswer.com > Network Experts Apr 6, 2014 - How do i type the plus sign for my wifi password on my panasonic viera remote? I also need to input the "+" sign. - Answered by a verified 1 answer · Top answer: Okay, great. Go to Network settings on your tv menu> select Wireless ne https://www.google.com/search?q=Panasonic+remote+plus+symbol ..
3/8/2024 5:06:23 AM • Panasonic... • Answered on Mar 08, 2024
Tv diagram tc 2165ga
panasonic tc-2165ga
2/26/2024 11:40:35 AM • Panasonic... • Answered on Feb 26, 2024
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector. Locate the lamp cover on the projector. Remove the lamp cover. Take out the old lamp. Insert the new lamp. Replace the lamp cover. Reset the lamp hours: Press the Enter button to display the "Option" menu. Use the 5 or 6 button to select "Lamp Runtime". Press and hold the Enter button for approximately 3 seconds. The "Lamp Runtime" will change to "Time Reset [Power Off]". Turn off the power and disconnect the power cord. Finally, plug in and turn on the projector. Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM • Panasonic... • Answered on Feb 17, 2024
How do I get my Panasonic television out of self check mode if I don't have the remote?
Question edited for clarity, it is probably a Viera not a Viesta. You can try a power cycle reset. Remove the power plug overnight, press and hold the On button for 60 seconds. Plug back in. All televisions need a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
1/31/2024 5:11:57 AM • Panasonic... • Answered on Jan 31, 2024
On the Panasonic DMR-EZ47V, it had a VCR tape stuck in it, when turn on shows, F60, now doesn't show anything.
Yes bad caps on the video processing board according to the links
SOLVED: F60 error on Panasonic DVD recorder - VCR
iFixit https://www.ifixit.com > Answers > View > F60+error... Oct 8, 2014 - Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board ...
I have a DMR EZ485 that shows an error code of F60. What
JustAnswer https://www.justanswer.com > Electronics Question Jan 5, 2018 - The F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ... 1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Panasonic DMR-ES40V Drive and F60 Code
AVS Forum https://www.avsforum.com > threads > panasonic-dmr... Oct 26, 2014 - F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked. But first try a "cold ...
Another Capacitor Failure, Another Fix
EE Times https://www.eetimes.com > another-capacitor-failure-a... Jan 21, 2019 - An online search revealed that F60 was a general failure code, usually caused by a failed aluminum electrolytic capacitor. Time to get the ...
Picked up a Panasonic DMR-EZ475V that throws a code ...
Reddit · r/VHS 2 comments · 2 years ago The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
My Panasonic DMR-ES40V DVD/VHS player now says " ...
JustAnswer https://www.justanswer.com > recorders-and-players Dec 23, 2012 - F60 is a general error code indicating a failure on the video processing board. First try a "cold boot". Unplug the recorder again, allow it to ... ..
1/30/2024 3:40:50 AM • Panasonic... • Answered on Jan 30, 2024
Panasonic PT-56DLX76 Television Logo
14 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
tv working fine earlier today now when
  • Televison & Video
