20 Most Recent Zhone (6218-I2-200) Router Questions & Answers
Check your online gaming server to see what ports or sites need to be opened up. The RTFM, Read The Flippin' Manual. Here's a link to the manual for your router.
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Good luck! :)
Zhone... | Answered on Nov 24, 2018
all routers work the same basic way. you connect a pc using a LAN cable to the router. You open a web browser and type in the IP address of the router. this is usually 192.1681.1 or 192.168.0.1 , but occasionally can be something else. its usually printed on a label stuck to the router. Once you get that right a login screen will appear and you must use the login user/password (admin,admin or admin,password is often used) which should also be printed on the router underside. Then the router will present a menu to you, and somewhere on there will be the wifi setup. they are all slightly different so refer to your manual or just use your common sense.
Zhone... | Answered on Oct 29, 2018
When you search for available wifi connections, do you find several routers? Other routers could be taking your bandwidth. There is a 802.11 protocol which establishes what channels routers can take, but this can be hacked, If you're in an apartment building, you may have this issue. Connecting by cable will fix it.
Zhone... | Answered on Nov 28, 2017
hi Jeffkrick.
if you go to the link you can read the manual.
when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it.
Zhone 6218 I2 User Manual
Zhone... | Answered on Nov 21, 2017
admin=username
cciadmin=password
for advanced users
Zhone... | Answered on Feb 04, 2016
I think you have forgotten your router password and want to reset it.
There must be a reset button on the back side of your router, which can be pressed with help of a hair pin or some pointed object. While the router is powered on, press the "reset" button and keep it pressed for more than 20 seconds (depends on your router specification). For my router I hold it pressed for 1 minute.The all your settings will be set to "factory reset", including your password. Usually factory reset password is "password" (it is true for my Netgear router). For your case the default password might have been printed on lower side of router.
You may now choose to change the password by connecting the router directly connecting it to your laptop and accessing the admin console of the router.
Hope this helps.
Zhone... | Answered on Feb 18, 2014
Try to insert the cable of the router at the back of your pc do not use the router so that you can now play and download files
Zhone... | Answered on Dec 04, 2013
If you connect to the router with network cable through one of the LAN ports you should be able to reset the wireless password.
Alternately if you know the factory default or if the factory default is on the router itself then there should be a reset button that if you hold down for a few seconds will reset the password to the default.
Otherwise if the router has a WPS button or similar then you maybe able to connect using that feature without the password.
Zhone... | Answered on Nov 22, 2013
Zhone (6218-I2-200) Router Logo
151 questions posted
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zhone Computers & Internet
Most Popular Question
find wireless network key router
  • Computers & Internet
