20 Most Recent
Fisher DD603FCSS Dishwasher Questions & Answers
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
F1 code. No water left in machine nor on the
Hi
Error F1 on your fisher & paykel means an
overfill condition. One of the most common causes for an overfill fault is that
the dishwasher cannot pump out the dirty water due to a plugged drain hose.
Check the drain hose if it is clogged. Now remove the bottom drawer from the
unit to inspect the flood switch. Remove the wire harness cover on the
underside of the drawer. With the bottom cover off, unclip the wire harness,
fill hose, and drain hose. Then unclip the linkage at the back of the drawer
and lift the drawer off the slider arms. Now' you'll be able to look at the
flood switch. Note the positions of the wires on the flood switch and remove
them. Then unclip the switch housing from the base panel. The switch housing
contains one switch for each drawer. The switches are wired normally closed
(NC) and each switch has three spade connections, so it's important to note
where the wires went. Now clean the contacts and let it dry. Hope this helps...
Please post back if you need more information.
Daniel
I have a Fisher and Paykel Dish Drawer dishwasher.
it is likely the lid seal is stuck. You will have to get the drawer out and check the underside of the cabinet at the top.
The lid seal is a rubber lining which is actuated by a pair of motors. If the motors are faulty or the power is to the motors is lost, then the seal will not go up to let the drawer sit properly.;
Flooding in both drawers of
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
How do you get the bottom drawer out for repair?
Pull out the draw all the way. Down both sides there are two plastic square buttons. push those in and at the same time push the rails back towards the dishwasher. it should come off the rails.
undo the pipes and pull the drawer away.
Our Westinghouse Touchdry SB915 stops
If the dishwasher is beeping 10 times and none of the functions work, it is highly suggestive of faulty control board. You could disconnect the power supply for few minutes,say 15 minutes and then turn it on. If the problem persists, more likely you need to replace control board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
How do you reset the flood switch on th DD603?
You have to either dry out the board at the bottom left hand corner of the dishwasher. Or replace it. If you are getting the error code you probably have bigger problems to consider. Moreover, you might have a lid problem thats causing water to leak.
Hope that helped.
Have a great day!
F1 alarm keep coming back on both drawer
I just had the same issue as a result of "mother-in-law" using regular liquid dish detergent in both drawers. After numberous attempts of cleaning out each drawer it still was beeping and attempting to drain both drawers even when the water was drained it continue to run and beep.
My presumption of what occurred is the wrong soup caused so much suds that it triggered the flood sensor. I removed both drawers and discovered water in the base area and moisture throughout. After disconnecting the power to the unit I removed the white plastic cover and exposed the small circuit board. I disconnected the power leads and the screw holding the board in place and lifted it up a bit. I then used a hair dryer for about 15 minutes until the entire area was dry and put it back together and has worked just fine. You will see a service diagram taped to the back pannel when you remove the bottom drawer. It has additional information on various error codes and the instructions on how to trouble shoot problems. I would also remind you to run water in the units if the cause was due to the wrong type of soap as the residue will continue to recreate the same problem.
I hope this helps.
Mark
RE: Fischer paykal F1 code
F1 fault means the flood switch on the base of the dishwashers has been activated.
nine times out of ten its the lid motors.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Dishes and Flatware Don't Get Clean
Check to see that the removable cup rack on the left is seated correctly. One of the support legs of this rack is located above center of the spinner. If this leg is sitting on the top of the spinner rather than the center cross member of the main rack, the spinner will not move after that rack has been loaded.
Also check that the spinner is free moving once the draw is fully loaded, some plates can sit low enough to obstruct the spinner.
