20 Most Recent Amana Comfort Zone 12M32PBEH Air Conditioner Questions & Answers
3answers
Furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
11/16/2022 2:03:29 PM • Amana Comfort... • Answered on Nov 16, 2022
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
12/13/2017 7:01:23 AM • Amana Comfort... • Answered on Dec 13, 2017
I Have a BDP Company
4 ton
9/25/2011 2:46:03 AM • Amana Comfort... • Answered on Sep 25, 2011
I too have the BDP
just a thought. Above most burners in furnaces there is a heat exchanger. If the are filters are not changed often enough and if everything does not fit exactly right then the fins on the heat exchanger will get clogged with lint and such. The exchanger looks like a car radiator. If the flow of heat can not easily move up through this exchanger then each time the furnace turns on the flames may burst out the front. I'd take apart your furnace. The exchanger is only a few feet above the flames. Take of the door and see what it looks like. You may be able to clean all the fins off and find that the furnace still works ok. But make sure you get them very clean and make sure you don't damage the fins. Then make sure you can have an extinguisher handy and test the unit. Just be very careful about assuming it is ok. Turn it up and down many time so that you see it turn on and off many times. There are many sizes and many different types so if you need to replace it you must choose wisely. And yes you can just replace that component. One other thought, you may find that replacing the whole unit will only be 1/4 more and if so the improved efficiency of a newer unit will pay for the difference in just a couple of years.
9/20/2010 6:27:28 AM • Amana Comfort... • Answered on Sep 20, 2010
Have an Amana 6300 BTU comfort zone ac if you
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/4/2010 10:03:08 PM • Amana Comfort... • Answered on Sep 04, 2010
On the Amana comfort zone air conditioner, there
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
8/26/2010 1:24:13 AM • Amana Comfort... • Answered on Aug 26, 2010
Thermastat is on, fan is running, but outdoor unit
By "outdoor unit", do you mean the compressor? The unit you describe is a window-mount, single-piece a/c.
Failure of the compressor could be:
Disconnected/damaged power wires.
Damaged current protector.
Defective control board.
Seized compressor.
8/14/2010 9:39:56 AM • Amana Comfort... • Answered on Aug 14, 2010
The fan is not running on the outside unit of
bad motor or capicitor
6/26/2010 9:30:39 PM • Amana Comfort... • Answered on Jun 26, 2010
Should the unit be recharged at some point?
Sometimes they leak and need to be recharged. There are other things to check first. #1 being filters. Then make sure your coils are clean, inside coil and outside coil. If all is well then you will have to get someone to check the system pressures to determine if it needs to be charged.
5/2/2010 11:00:53 PM • Amana Comfort... • Answered on May 02, 2010
I have an Amana dinosaur model P67470 dual
Not an easy one to get to. From the gas valve, follow the small 1/8" diameter (usually copper) line toward the heat exchanger. It will lead to a pilot assembly just over one of the burners. Using a long match or shis-ka-bob stick, hold a flame just over the pilot assembly until you see the pilot light. Remember you will need to have the gas valve knob on the Pilot setting and depressed into the gas valve. Continue to hold down on the knob for 15-30 seconds. Then after the pilot remains on, rotate the gas knob to the On position. Hope this helps!
10/21/2009 7:25:28 PM • Amana Comfort... • Answered on Oct 21, 2009
Mymodel is about 10 years old. during these hot
wash the outdoor coil it sounds like a code for high pressure also wash indoor coil these 2 corrections will cure most problems
8/11/2009 11:20:25 PM • Amana Comfort... • Answered on Aug 11, 2009
Amana ultron 12 seer 2 yrs old compressor does not
is it a split system? majority of problems, lets say 95% occur during install, u may have a leak! A pinhole at that, but maybe installer missed it, your out of labor warranty, call a 3rd party contractor and have them inspect it!
8/6/2009 5:05:43 AM • Amana Comfort... • Answered on Aug 06, 2009
Amana Comfort Zone 12M32PBEH Air Conditioner Logo
Popular Tags
35 questions posted
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
unit recharged some point
  • Heating & Cooling
