20 Most Recent
Kyocera RI-3530 Black and White Copier Questions & Answers
How to repair with Toshiba copier 2060
lan lam... "insert key counter" means that the machine has an external control device. Usually a small box the size of a pack of ciggerettes or smaller) with a mechanical counter that needs to be inserted into a port on the machine in order for it to operate. Companies used this to "control" and/or track machine usage by department or person. It may be that your machine has one but it's not inserted well enough, or you are missing the counter comepletely. If you don't have one of these control devices, you will probably need a certified technician to come out and disable this feature.
Kyocera KM-2530 printer displays "Attach
on the copier metal bracket that finisher attaches far end or front ull see a metal pin that sticks out.
That pin goes in to the finisher white plastic hole.Inside that hole there is a switch that tells the copier the finisher is attached.
Morning,
A C6000 is as follows:
Broken fixing heater wire In fixing warm-up, the time to reach
50°C/122°F exceeds 13.5 s, the time to reach 100°C/212°F exceeds 10 s, the time to reach the primary stabilization
exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s.
Solution:
Fixing heater M or S installed incorrectly.
Check and reinstall if necessary.
Broken fixing heater M or S wire.
Check for continuity. If none, replace the fixing heater M or S
The heating M or S are the hologen lamps inside the unit.
You can try to reset the fuser by entering the following
10871087 this will put you in maint mode.
163 then press start and you may have to press start again. If start doesn't work then you have to press ok.
then unplug unit and wait 30 secs. and turn back on.
Hope this helps.
Morning,
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
Ri-3530
Check your toner cartridge, it is trying to add toner.
Any idea what the default
Few of the copier have Blank Password. Do not put any password. Enter Admin account and follow without punching anything in password.
Let me know, if problem persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Xerox XD100 copier
occasionally on that model it will run continuously looking for toner when it has actually run out.....so check the toner, it does not always indicate toner required
Need to be fixed
either the toner output voltage is inaccurate,poor contact,no contact at ll or the toner sensor is faulty replaced it.
Need help
we do not have that brand in the US The only E1 problem I can find is for Toshiba and Xerox ( is that who makes Nashua??)
E1 is paper jam inside machine, look for paper on sensor
Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
Xerox copier
J messages on Xerox machines always refer to toner or drum.Is the toner out , you could give it a shake (might be a good idea to go outside!) Sometimes it will run out without displaying a message(Pyramid of dots for out of toner) Drum end of life usually comes up with a crossed circle or similar .If all OK you could have a blocked toner supply auger or lumps caused by storing toner in sunlight, both would require the toner system being vacuumed out.
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Light copies
toner sensor not set properly, or the toner sensor is bad. what is the make and model, it would help to solve your problem faster.
Copier problems
Sounds like its stuck, try removing the glass and moving the scanner assy. manualy. move it all the way to each side then put in the middle. turn the power on and watch it,if you still have the problem you most likely will have a bad home switch or sensor.
