20 Most Recent Panasonic DMP-BD10 Blu-Ray Disc Player Questions & Answers
Panasonic BD10 player: region free?
ask panasonic they will unlock it for you.
5/24/2021 10:35:35 AM • Panasonic... • Answered on May 24, 2021
2answers
Hi Could any one please help with a region unlock code for a Panasonic 3d blu ray player model DMR-BTW 829 GL many thanks
You maybe able to get a region free code for your player from these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm
2/14/2020 8:40:30 AM • Panasonic... • Answered on Feb 14, 2020
0answers
2answers
I'm looking for the Multi-Region code for my new
I'm sorry for the difficulties you're experiencing in playing the other region DVDs in the player. Unfortunately, there is no direct way to hack using the supplied Remote.
However, it is possible that if you purchase the All URC-7740 remote to hack the player. Once you get the player, please follow the below steps:
1. hold magic button until the DVD button blinks twice 2. press 994 (magic button blinks twice) 3. press magic 4. enter 5 digit code from above 5. press button (1..0) where to program it (magic button blinks twice) 6. repeat steps 1 to 0 for all keys.
Thanks for understanding. Please let me know if you require any clarifications.
9/17/2011 3:28:19 PM • Panasonic... • Answered on Sep 17, 2011
Player says please wait. can't get disc out of
Hello there,
First Step i would do is removing the Power from the unit for a 1 min then plug it back in .
If this Step fails let me know
1/27/2011 3:45:04 AM • Panasonic... • Answered on Jan 27, 2011
2answers
My BD10A will no longer play blu-rays, only
ALOT OF THE NEWER DVD PLAYERS YOU CAN GO ON THE MANUFACTURES WEBSITE AND DOWNLOAD THE FIRMWARE UPDATE WHICH WILL MOST LIKELY FIX YOUR PROBLEM. ATTACHED IS THE SITE YOU WILL NEED.
http://www2.panasonic.com/consumer-electronics/support/Video/Blu-ray-Disc-Players/Drivers-Downloads/model.DMP-BD10AK.D#ts
7/17/2010 2:19:37 PM • Panasonic... • Answered on Jul 17, 2010
My panasonic dmpbd10a blueray player wont play
With people downloading movies illegally, companies have put blocks on DVD's, unfortunately making the DVD unplayable for some blue-ray players
http://www.njnnetwork.com/2010/04/avatar-blu-ray-wont-play-on-all-players/
5/13/2010 8:17:52 PM • Panasonic... • Answered on May 13, 2010
What does it mean entering the encription key of
If your player is connected to the internet then you need to check your wireless router. You could first try power cycling the router by unplugging the power cord from the back of your wireless router for 15-30sec or get a paper clip and hit the small reset pin hole on the back of the router. If your still getting this message then you need to find out what wifi security phrase or code is on your wifi router either you have WEP or WPA-PSK security code for your home network. The access point is your wireless router or Modem. If you do not remember or have the passkey then you need to contact your internet router/modem manufacture.
4/25/2010 2:05:57 AM • Panasonic... • Answered on Apr 25, 2010
2answers
I just need an owners manual for PANASONIC blu-ray
Click Panasonic Support to download instrcution manual copy of DMP-BD10A.
Thanks.
2/15/2010 9:29:44 PM • Panasonic... • Answered on Feb 15, 2010
HOW CAN I MAKE THIS PLAYER MULTI REGION
Try www.cnet.com
5/28/2009 5:03:12 PM • Panasonic... • Answered on May 28, 2009
Panasonic hds700tds playing audio no videos
  1. Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
  2. Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
  3. Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
  4. Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
  5. Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
  6. Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
  7. Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
  8. Hope this helps
4/9/2024 11:43:10 PM • Panasonic... • Answered on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
  1. Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
  2. Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
  3. Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
  4. Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
  5. Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM • Panasonic... • Answered on Apr 09, 2024
I'm about to lose my mind trying to find the + on a Panasonic remote! Can anyone tell me how to find it? The + is part of my router code to connect my tv to the internet.
Unfortunately there isn't one. The workaround is to change the Router Password or SSID to remove the plus + for something else.
need to input the plus sign for wifipassword XXXXX my ...
JustAnswer https://www.justanswer.com > Network Experts Apr 6, 2014 - How do i type the plus sign for my wifi password on my panasonic viera remote? I also need to input the "+" sign. - Answered by a verified 1 answer ยท Top answer: Okay, great. Go to Network settings on your tv menu> select Wireless ne https://www.google.com/search?q=Panasonic+remote+plus+symbol ..
3/8/2024 5:06:23 AM • Panasonic... • Answered on Mar 08, 2024
Tv diagram tc 2165ga
panasonic tc-2165ga
2/26/2024 11:40:35 AM • Panasonic... • Answered on Feb 26, 2024
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector. Locate the lamp cover on the projector. Remove the lamp cover. Take out the old lamp. Insert the new lamp. Replace the lamp cover. Reset the lamp hours: Press the Enter button to display the "Option" menu. Use the 5 or 6 button to select "Lamp Runtime". Press and hold the Enter button for approximately 3 seconds. The "Lamp Runtime" will change to "Time Reset [Power Off]". Turn off the power and disconnect the power cord. Finally, plug in and turn on the projector. Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM • Panasonic... • Answered on Feb 17, 2024
Panasonic DMP-BD10 Blu-Ray Disc Player Logo
23 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
  • Televison & Video
