20 Most Recent RCA Scenium M50WH187 50" HDTV Questions & Answers
RCA Scenium 50 inch DLP Projection HDTV
The color wheel isn't spinning.
8/16/2017 5:48:06 AM • RCA Scenium... • Answered on Aug 16, 2017
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
5/1/2017 4:51:36 PM • RCA Scenium... • Answered on May 01, 2017
My RCA scnium picture is out and the sound on but is making a loud sound
i would look at the lamp but with our a model number its hard to tell which one you have . but the sound will be heard when the unit initializes for start up its a buzzing sound ?
1/7/2015 4:27:13 PM • RCA Scenium... • Answered on Jan 07, 2015
Why won't my tv turn on by the button
Power switch may be broken, seems tio be a common problem on these tv's
11/26/2014 1:39:09 PM • RCA Scenium... • Answered on Nov 26, 2014
0answers
0answers
0answers
Tv will not power up
•Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.•Make sure the TV is plugged in.•You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.•Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicatoris blinking or flashing section below for more information.•When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 secondsand then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV canonly be turned on after the Power indicator goes off.•Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.•Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check theremote control solutions on page 53.•Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then AdvancedOptions, then Multiple TV Setup. Choose TV (default).
9/26/2013 11:39:38 AM • RCA Scenium... • Answered on Sep 26, 2013
How do I change the picture tube
your model doesnt have a picture tube it has a lamp instead which is easially relaced by removing the lamp door screww and then the screws that secure the lamp cartridge then it just s;ides out.
4/2/2012 3:06:14 PM • RCA Scenium... • Answered on Apr 02, 2012
I have sound to my
try to check first if there is a voltage input in to your ballast before replacing it. If there is a current going to your ballast and the bulb still not powering for sure the ballast is defective and you can replace it.
8/2/2011 4:46:04 PM • RCA Scenium... • Answered on Aug 02, 2011
Once i power on my
Very likely, the bearings on the Color Wheel have worn out and the Color Wheel assembly will need to be replaced. This is usually something that can be done by someone with a reasonable amount of technical competence, and isn't very expensive to accomplish. Many tutorials are available on YouTube, describing the process of replacing DLP projection Color Wheels.
7/24/2011 12:22:08 AM • RCA Scenium... • Answered on Jul 24, 2011
3answers
My RCA Scenium 50in. is not turning on!!
toss it out
5/17/2011 10:38:16 AM • RCA Scenium... • Answered on May 17, 2011
Fan is very loud, is
Hello
Look for some external materials like hard flyes or such small and hard materials in between the leaf of the fan, which make noise. It is quite commot that flies are trapped inside it. If so, open your device and clean the fan leaf. Do it very carefully not to make it break. If there is no such materials, and still fan has sound, peel off the the label on the fan, and you can see a bush joint that comes from inside where the shaft of the fan is fitted. Put a drop of lubricatin oil and see whether it helps you. If note of this helps you, just repalce the fan with a similar one. OK.
4/25/2011 4:24:20 PM • RCA Scenium... • Answered on Apr 25, 2011
Can I replace the bulb
The bulbs on projection tv's are typically designed to be replaced by the owner of the TV. They are a big pricey though. Do a good search online to try and get the best price. There will usually be instructions included with the replacement bulb. If not, visit RCS's website and download the manual. The unit that needs to be replace is typically located on the back of tv and secured with several screws. There will be a wiring harness to unplug and the unit will slide out. Just replace the bulb and reinstall the unit. Remember to NEVER touch the bulb itself with bare hands. Any oils from your skin can cause the bulb to prematurely burn up or even break immediatly when turned on.
3/2/2011 2:03:12 PM • RCA Scenium... • Answered on Mar 02, 2011
I won a rca scenium
Hello. I do hope that you have gotten this resolved. But if not, here are some simple steps.
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable- the TV needs to be on an HDMI input
If you are using component cables-the TV needs to be on a component input usually
If you are using RCA cables-the TV usually needs to be on a VIDEO like Video 1 or2
If you are using coax cable-the TV needs to be just on channel 3 or 4.
Becki Barned
DISH Network Customer Service
2/23/2011 11:02:25 PM • RCA Scenium... • Answered on Feb 23, 2011
Changed the lamp and ballast. It turns on but
The tv shuts down because the protection system of the power source detects an excessive current on one of its outputs and cuts it down.To find out the failing part that consumes extra current you will have to check the output voltages - start with the wheel motor and its power line.
And, as usual, don't forget to check all the capacitors .
1/11/2011 11:25:58 AM • RCA Scenium... • Answered on Jan 11, 2011
My 36in flatscreen tv
The problem with the tlevision is that either the lamp is faulty or the t-com board is bad.
First ensure that your television is not display is not turned off from the menu and there is not screen saver set up on it. if that has been confirmed, then the problem is from either of the afforementioned causes.
To check if it is the lamp, then you have to unscrew the television open then assess the lamp, if it looks burnt or broken, then you replace it with a new one, and if the lamp looks okay then it is the t-com board that needs to be replaced.
Take care and good luck
10/27/2010 5:41:28 AM • RCA Scenium... • Answered on Oct 27, 2010
RCA Scenium M50WH187 50" HDTV Logo
46 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
changed lamp ballast turns but
  • Televison & Video
