20 Most Recent
Audio Technica ATH-A900 Professional Headphones Questions & Answers
How do I open Audio-technica ATH-911's? One of th...
hi.First of all: This headphones don't have a single srew. So be extremely carefull as everything is glued !#1 - Removing the logo plateThis isn't need to reach the wires. Just for cleaning purposes.Remove de soft ring-pillow from the earing.Remove the textil thick black ring that is glued by the internal outside gently.Look for the three black metal small wings that belong to the logo plate and are inserted to the internal side and are glued and/or bended. Unbend them.Then pull this wings in order to extract the plate by the outside side the logo plate.#2: Accessing the speaker and it's wires.This is a very carefull procedure. A mistake and you'll have scrap instead!Remove the soft ringed pillow from the earing. In the border that the blacksinthetic leader was inserted, insert a medium screwdriver. Gently swingthe driver up and down in order to separate the plastic disc that supportsthe ringed pillow from the outside hat of the earing. Do this in circles fora couple of times or until you begin to ear the glue lightly cracking. Afterthis the plstic disk separates from the outside hat and all the electricwiring and speaker are free to repair.NOTE: A piece of advice: do NOT use instant glue or cyanide glue to re-assemble. It would be the last repair! Pedro Regueiras
Audio technica at 120 cartridge will fit my project essential?
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
