20 Most Recent
Kenwood KDC-MP235 CD Player Questions & Answers
Unlock code for kenwood kdc-mp235
This Ebay auction
170150626863
will remove the code for 40.00 including shipping, or you can contact Kenwood at 1-800-KENWOOD (536-9663).
Good Luck.
Leadispenser
6/1/2018 12:44:36 PM •
Kenwood...
Answered
on Jun 01, 2018
My radio cuts off and says call whenever i am
Hi Call on display means Call Service.
That means that a short or an incorrect voltage had been detected. The unit goes off to prevent further damage.
If this happens with vibration, or when turning on the ignition then it is usually a bad wiring at the back of the unit.
4/12/2015 1:50:43 AM •
Kenwood...
Answered
on Apr 12, 2015
Cannot grab even frequences in radio, any idea how to recover ?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
On many imported cars , the radios have options for
different areas of the world (UK/EUROPE : ASIA
: USA+Americas etc. )
This means that your radio frequencies may be setup for a different part of the world to where you actually live...and so it requuires changing
If you have a MENU
button on your radio , see if you can
find this Area choice option.
Once found , then it is
just a matter of switching to the area required ( In your case UK/EUROPE)
3/19/2015 7:46:33 AM •
Kenwood...
Answered
on Mar 19, 2015
SP OFF mode?
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
1/29/2014 9:25:28 PM •
Kenwood...
Answered
on Jan 29, 2014
