20 Most Recent
Haier HWD1000 Questions & Answers
My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
DISWASHER hdw100wht
You could if you wanted a hot wash. You cannot dry without cold water. The dryer cycle requires cold water to draw moisture out of the clothes.
You can create a custom program that has no dry cycle. I usually do the laundry this way and hang dry, however I only have cold water hooked up.
You could get cold from the cold tap by installing a few outdoor hose quick connect parts to the tap if your faucet ends in a screw fitting. You may also need screw on expander for this to work. Go to you local hardware store and tell them you want to get the outdoor hose quick connect parts and an expander to fit on your household tap. Buy metal parts NOT cheapo plastic.
E 31 error message on Haier HW1000
E31 Motor
The feedback signal does not change in 8 minutes during the motor runs <-- Bad translation that probably means bad sensor or electronics issue.
Call repair people and then get a new machine sent if still under warranty.
ERROR LOCK CODE: LOC
push temp button #9 and hold for three seconds LOC should clear. press the same button and it will lock controls again-but I don't know why you'd want to do that-cheersDenny
My washing is saying error 2
E11 is low water pressure
E12 is a slow drainage problem
E13 too much water
E31 motor problems
U02 is cannot lock the door after 20 seconds
E22 is memory failure
what exactly does the error message come up with and when does it occur
Which compartments are for detergent, (and
Of the three chambers, the only one designed to take liquid is the softener. This will have some sort of syphon in it. The other two are prewash (smaller) and main wash (larger). Regarding the instructions, this unit is made in China and is probably translated incorrectly (I'm not being funny on this one)
