20 Most Recent
Amana NAV5800A Top Load Washer Questions & Answers
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
