20 Most Recent
Gestetner DSm635 Copier Questions & Answers
Sc ricoh 322
Bad laser diode unit. It either just went bad or it has toner in it. Must be replaced - part number:
B0821891
It has to be replaced and an alignment performed. If not aligned it will not operate without throwing an error code.
LIGHT COPIES
when i switch to scart it says no video so i can get on xbox
Error sc 326 in dsm 635
First of all check that the laser **** glass is still there, I've seen a couple of machines where the **** glass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
Se 361
that means yo have bad sector in your hard disk part of this hard machine can't read it easly solution for this proplem unplage power and data socket from hard and it's works but did't work duplex mode
Our Gestetner DSM635 jams every time we try to
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving
I have problem model ricoh
you proplem with laser unit sychro2 not detected try to clean mirrors inside laser and be carful if it's not work out change it and go to programmes and put 2-109 and 2-108
How to install gestetner DSM
open finsher and yo will find like knob pull it yo will find wth our languge lokcha this expression refer to stapler
How to Network the scan function of a Gestetner DSm635
The only real problem would be finding the software driver for your machine.When your driver for your scan function is loaded it will assign an IP address for the scanner.without the software,your out of luck.I'll look online tonight for it and let you know if I find it.
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
