As have been posted in a
post of similar concern...
You can try calling Target Customer Service 1.800.440.0680 and inquire
cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC
27615,
(800) 252-6123)
Should you need direct Customer Support, please
try
here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector
- one that will fit and match the polarity of the TruTech PVS12701. (am
guessing crown type center positive, pls confirm with the store. It may
also help to bring along the unit when doing the purchase over the
counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
