20 Most Recent
Sharper Image Ionic Breeze GP (SI730) Air Purifier Questions & Answers
Makes a hissing sound after I clean it
It may be a little late that I am answering your conundrum, but once you clean it, put the unit back together, tip it upside down until you hear a "click" and then turn it on. No hissing :)
No power.
there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
Condensation forms on the top inner ceiling of the refrigerator
Very common problem I have repaired many times , The drain is frozen or plugged.
remove the back panel in the freezer section to get to the evap./cooling coil , then check the pan under it , there is a small 1" drain hole at the bottom that may have ice in it or its clogged with something else.
Use hair dryer or similar to remove ice then get a wire or something similar that is firm to use to snake out and clear that drain hole you want to get about 10 inches down into it.
Pour bleach into evap pan and let it sit for a bit. [10 minutes]
Then to know its cleared well pour a cup of water into the evap pan then check the pan under the unit at bottom behind kickplate to ensure the bleach and water has made it to this pan.
If unit is now draining here , wipe remaining water off top of ref. compartment and by the next day it will usually stop.
Let me know if you have any other questions.
Phil
Ionic Breeze GP unit does work.
Could be a problem with the power cable or a fuse issue. Or it could be a burnt wire, or motor problem. It is difficult to say without actually taking it apart. Best get it serviced.
