20 Most Recent
Whirlpool ES5FHAXS Side by Side Refrigerator Questions & Answers
WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
2/21/2024 7:02:59 PM •
Whirlpool...
Answered
on Feb 21, 2024
Frost builds up on the line leading to compressor
very possible
you can overcome the problem by preventing the air getting to the pipe by wrapping insulation around it
fridge repair shops and suppliers sell insulation that can be fitted around the suction pipe to prevent that problem
9/9/2017 11:30:35 PM •
Whirlpool...
Answered
on Sep 09, 2017
What's your problem?Ice Dispensor not makine ice
HI.not making ice could have many reasons.run through the basics first ok.1-lever down above ice box 2-water turned on 3-water inice tray.should do automatically **** pour some manually if empty.try this firstok?good luck ali
6/15/2012 12:50:27 AM •
Whirlpool...
Answered
on Jun 15, 2012
Un hook the water line from door on whirlpool
Push in on the end ring , pulling the tubing out at the same time . If you have the blue connector with white end rings , Push in on the ring oan pull out the tubing at the same time .
12/6/2011 12:07:30 AM •
Whirlpool...
Answered
on Dec 06, 2011
My two year old refridgerator
Since the ice production depends on the temp in the freezer, your freezer may not be as cold as it use to be. Should be at least 10 degrees F. If you're having a defrost problem that would cause the temp to be higher than normal.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
12/26/2010 4:28:26 PM •
Whirlpool...
Answered
on Dec 26, 2010
Twice in the last month
check the door seal as it sounds as though your getting warm air in the refrigerator compartment and when this warm air gets near the damper vent door between the fridge and freezer it condenses from the cold air from the freezer and freezes the door motor in that position so it cant adjust,also putting warm foods near there when first put in can contribute to this condition also,clean door seal and door land where seal makes contact and make sure seal is in good shape all around the doors,you can clean them with isopropyl alcohol
12/5/2010 11:38:54 AM •
Whirlpool...
Answered
on Dec 05, 2010
How do i get the water dispenser cover off
Hello, in order to remove the dispenser from the refrigerator you will need to use a screwdriver and leaver around the edge carefully. The dispenser is held on by plastic clips.
If you want to know any further questions please feel free to ask.
11/17/2010 5:13:11 PM •
Whirlpool...
Answered
on Nov 17, 2010
Doesn't cool properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
9/20/2010 11:36:30 PM •
Whirlpool...
Answered
on Sep 20, 2010
