20 Most Recent
Ariston Technologies AW129NA 16 Lbs Front Load Washer Questions & Answers
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
5/30/2012 11:12:40 AM •
Ariston...
Answered
on May 30, 2012
The On-Off door lock LED
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
5/4/2011 8:44:19 AM •
Ariston...
Answered
on May 04, 2011
How to replace a door
Hi.
The procedure is quite complicate, because the seal is secured to the front panel, and you will need to remove top panel, detergent drawer and access control assembly
- Disconnect appliance from power
- Remove the door, held by two screws located on the rear side of the lid.
Lift the top panel, held by two screws at back.
Undo the two screws joining the detergent dispenser to the inlet valve.
Undo the two screws located at the front corners.
So to release the fascia and dispenser.
take out fascia and the dispenser alltogether and put it on one side. Take care to not disconnect wiring and do not drop parts.
- Release the retaining wire
that keep the seal secured to the front panel. Look after it, you will need it again.
Undo the two screws that hold the front pane. They are located on the front side.
Remove the kick panel
- Behind the the kick panel you will find the two screws that will release the front panel, remove both of them.
Disconnect the door switch conntector.
- Lift the front panel. You may need to help yourself using a putty knife.
- Remove the clip with two hooks inside, it is located at about one o clock. This will finally release the seal.
- Remove the seal and clean the area where you will fit the new seal.
- Start mounting the seal from the lower part on the right, at about four o clock. You will notice the seal matching.
Put back the retaining wire usingf long-nose pliers to put the wire in tension.
- Reassemble the washer in reverse order.
Unfortunately we do not have step by step pictures. I hope that my instructions had been enough clear and detailed.
Regards.
4/8/2010 3:51:44 PM •
Ariston...
Answered
on Apr 08, 2010
Washing machine keeps chipping out
Take out the filter and wash it thoroughly, also flush the outpipe to make sure the whole system is clean. Does it give you an error code?
2/2/2010 10:43:15 AM •
Ariston...
Answered
on Feb 02, 2010
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
1/20/2009 6:38:42 PM •
Ariston...
Answered
on Jan 20, 2009
Closed door
Dear babmat: just now got your question.
We are very satisfied with our ARISTON Washing Machine. I trust that that is what you are inquired about?
I had the same problem the first time. This locking occurs when one opens or tries to open the washing machine door too soon!!!! It has to be left alone for a few minutes. When I waited and later tried again to open the machine, I did not have a problem.
Just wanted to leave this note for anyone who encountered the same problem. You, yourself, hopefully, might have gotten that answer and the problem fixed in the meantime!?
Greetings, handinovice
11/1/2008 4:46:57 PM •
Ariston...
Answered
on Nov 01, 2008
