20 Most Recent
Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N) Questions & Answers
Problems big problems
Verify that TCP/IP (or other appropriate protocol) is properly installed.
- Open Control Panel and open Network Connections or Network and Sharing Center, then click Change adapter settings. The wireless card should be present as Wireless Network Connection.
- Right-click the appropriate Wireless Network Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) or Internet Protocol Version (TCP/IPv4) is installed.
- If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP.
- Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties.
Note: Only use a Static IP Address if your network/Service Provider requires one.
8.Verify the TCP/IP address.
- Click Start, select All Programs, select Accessories, and then click Command Prompt.
- Type the command, ipconfig. This will list the IP address for the local machine.
- If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands;
ipconfig /release and then
ipconfig /renew.
You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address.
- Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway. (i.e. ping 192.168.1.1)
- If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.
- If you are connecting wirelessly, but receiving an IP address, your wireless router/Access Point might need to be reset (unplug power for a minute, then plug back in), or maybe defective. Please consult your wireless router/Access Point manufacturer for further assistance.
9. Ping the loopback address.
- Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this:
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<10ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milliseconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
- If instead, you receive errors, then there maybe system corruption or malware installed preventing networking from functioning properly.
10. Verify that the hardware is functioning using diagnostics.
- Check the web site, http://support.lenovo.com. Choose Download Drivers and Software and enter your particular system. Then under Diagnostic choose the download for your system. If diagnostics fail, please contact warranty support for resolution.
- Run diagnostics for third party wireless card.
Note: If using another manufacturer's product, then consult it's documentation on how to run the diagnostics for the wireless card.
Network adapter card problem
Hello. Did you reinstall Windows using the disc from Lenovo or was it an off-the-shelf/torrented version? If you contact the Lenovo support line they will be able to send you a disc with all your drivers. The support phone number is 1-866-96-THINK (1-866-968-4465).
Audio pblm
make sure that you know the model of your motherboard and the chipset number. now connect to the internet and search for the driver of your motherboard. look for the chipset driver and install it on your pc. this will solve your problem.
A simple thanks is enough...
Can't start my wireless modem
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Cannot get wifi using Anatel 802.11 a/b/g mini pci
2 things, did your Wi-Fi pci-card come with laptop or did you bought it later, if its the later it could be a authorizing issue, or else it could be the router misconfigured for the computer like the new routers with WPA2 protocols doesnt "seeing" the old b or g cards in laptops
I have an IBM Lenovo
Welcome to Fixya
Make sure that all driver are installed. Especially the wireless LAN driver. Go to control panel then click on system then click device manager. Look for the network adapter category. There should be no exclamation mark to any of the devices listed there. You can download all your computer drivers
here. If everything are ok then all you need to do is to go to control panel. Click network connection. Look for icon named Wireless then click on it. Search your router and connect to it.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I need to connect ThinkPad R60 to my wireless
place the mouse cursor over the bottom right screen, you will see an icon
select it and right click , go to OPEN NEWTORK .. i assume you have high speed modem thats linked to a a router -- select YOUR newtork name -- the others are surrounding neigbours that are close proximity to your network. you will have to know the password or key to enter
if you dont know that get in contact with your ISP and get them to help you connect
please post a positive feedback response for me
