20 Most Recent TurboChef TORNADO Electric Oven Questions & Answers
2answers
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
10/27/2020 12:43:36 AM • TurboChef... • Answered on Oct 27, 2020
Our Subway Turbochef Toaster has a keypad issue.
check pad connections if all good you need new pad
11/26/2018 8:07:55 PM • TurboChef... • Answered on Nov 26, 2018
2answers
"F3 MAG CURR" error message,
Its a big pain in the *** issue.
IF YOU KNOW HOW TO USE CLAMP AMMETER THEN ONLY YOU CAN USE MY METHOD TO TROUBLESHOOT IT.
MAKE SURE OVEN HAS 5000V IN THE CAPACITOR.DISCHARGE THEM FIRST .
AND IF YOU DON'T KNOW THEN STOP HERE
STEPS
1. open right side pannel
2. press back key to turn off oven
3. press back and enter key simultaneously.
4. enter 9428 then press enter.You are directed to testmode.
5.put clamp ammeter on the primary wire(orange in color).The one which come from top and looping the IO board.
6.Under Displaty screen you see Word Magnetron.Press and hold the soft key to energize the magnetron.
7.Check the amperage.It should be under 14-16 Amps.
8.If its half of the value or nothing comes then.
9 half value means(one magnetron is working
10. No value means F3 fuse blown and check the cause why it blown(physically look at the transformers and the capacitors and the diodes that they didn't burnt or change their shape.
IF YES THEN REPLACE IT.
OKAY LET ME KNOW IF YOU CAN REACH UPTO HERE .
AND REPLY ME
THNAKS
PLEASE RATE MY WORK
5/18/2018 2:21:10 AM • TurboChef... • Answered on May 18, 2018
2answers
F3 magnetic curr
your mags failed replace 20 amp fuse and figure out cause probaly bad mags or transformers.
11/24/2016 12:24:06 AM • TurboChef... • Answered on Nov 24, 2016
2answers
F3 mag error. can it be the waveguides.
What is your amp draw? You could just have a bad I/O board.
10/6/2016 3:30:58 PM • TurboChef... • Answered on Oct 06, 2016
2answers
My TurboChef Turbochef Tornado starts
replace 3 door switches, very cheap fix. bout $2.50 per switch and all you need is a screwdriver.
9/22/2016 9:25:53 PM • TurboChef... • Answered on Sep 22, 2016
Turbochef tornado electric oven overheating and
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
3/24/2016 6:43:18 AM • TurboChef... • Answered on Mar 24, 2016
Oven showing door close error with _ _ M
there are little switches inside that the door hits when you close it. open both side panels then open and close the door. you'll see them in the upper left. there primary, secondary, and monitor. PSM. they either broke or something need adjusted. easy and cheap fix. you could take the leads off and jump them until you get switches. but they are a safety feature so do at your own risk.
7/12/2015 9:19:15 AM • TurboChef... • Answered on Jul 12, 2015
My Subway TurboChef will not get hot - who or how can I repair this
You may need to replace the heater coils. Contact the manufacturer for details.
6/8/2015 5:41:18 PM • TurboChef... • Answered on Jun 08, 2015
Oven still in warming mode for the whole day
Call a tech and let him check t he t top heater. Lose connection maybe AT terminal OF CC heaTER
12/8/2014 6:40:09 PM • TurboChef... • Answered on Dec 08, 2014
When preheating the oven and it reaches 1000 degrees the ready word wont pop up on the screen. When setting a set temperature or time and the oven reaching that time the bell will not ring. How can I
Relay . Also u have to update ut menu program using hi density card account with latest program .....
12/8/2014 6:33:21 PM • TurboChef... • Answered on Dec 08, 2014
Turbo chef oven not toasting
Heater...top or bottom. Call a tech
12/8/2014 6:30:02 PM • TurboChef... • Answered on Dec 08, 2014
2answers
F3 Mag Low Current
did you check transformers. also k1 , k2, k3, relays. also make sure all wires are put back right and the diodes are going in the right direction.
12/8/2014 6:27:08 PM • TurboChef... • Answered on Dec 08, 2014
2answers
Turbo chef tornado f3 smoke and bad smell
James 938 hit the nail on the head. These ovens are very good and tend to be maintenance free, however, when it does have a problem, it is an unusual one. Good luck and let us know how it does.
12/8/2014 6:23:41 PM • TurboChef... • Answered on Dec 08, 2014
Tornado turbo chef Oven give f3 fault after16 secs
the most complicated error for this oven ... this error affects ur micorwave system .... this requires a tech to check ur unit
12/8/2014 6:14:59 PM • TurboChef... • Answered on Dec 08, 2014
I bought my turbochef NGCEW ex Subway. It heats up no problem and then shows the Subway menus but I can't seem to access the edit menu. Also, some of the keys don't beep when I press
This might help you out: http://www.basequipment.com/v/service/TurboChef/NGC.pdf It's a service manual for the TurboChef NGC Tornado. Pay particular attention to pages 15 through 19. It shows you how to edit menus and to reset everything. Good luck!
10/24/2014 1:43:32 AM • TurboChef... • Answered on Oct 24, 2014
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
10/2/2014 4:18:15 PM • TurboChef... • Answered on Oct 02, 2014
How to replace thermo fuse RBD305PDB12
havent seen any fuse of this kind in turbochef. it only has 2x12amps and 20amps slow blow fuses
10/2/2014 4:14:26 PM • TurboChef... • Answered on Oct 02, 2014
I have a Turbo chey NGo oven and front keeps saying door open, when its not open
ur door microswitch defective ....
10/2/2014 4:12:44 PM • TurboChef... • Answered on Oct 02, 2014
2answers
Why is the oven bell not ringing when it reaches the set temperature.
If the temperature reached at it operating temperature and oven display doesn't showing how much time left for ready screen then most probably its IO board gone. I have seen many cases like this, and replacing IO Board fixed the problem. Please rate my work Thanks Sagar
9/19/2014 7:29:14 PM • TurboChef... • Answered on Sep 19, 2014
TurboChef TORNADO Electric Oven Logo
221 questions posted
Top TurboChef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
View Most Popular
TurboChef Ovens
  • TurboChef Ovens
Most Popular Question
turbochef problem door magnetron blower
  • Ovens
