20 Most Recent Splendide 2000S Vented Washer/Dryer Questions & Answers
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Splendide 2000S... | Answered on Sep 02, 2019
drive motor or belt came off or broke take off top
Splendide 2000S... | Answered on Jan 20, 2018
check vent for obstruction if ok bad heater element
check lower right side filter
Splendide 2000S... | Answered on Nov 25, 2017
check to see if belt broke or came off
Splendide 2000S... | Answered on Oct 29, 2017
check lint traps on bottom and inside top and vent
Splendide 2000S... | Answered on Sep 22, 2017
check vent for lint and clean out filter on bottom right
bottom lower right remove panel drain if ok then lint filter inside top or lint in vent
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Splendide 2000S... | Answered on Sep 17, 2017
check inside weight might have moved or came loose
Splendide 2000S... | Answered on Sep 11, 2017
perhaps the manufacturer thru their website and customer support
Splendide 2000S... | Answered on Feb 01, 2016
Remove the top and loosen the clamp around the spin tub. Remove the two screws on the hinge on the door to get it out of the way. remove the clamp around the diaphram in the door. This will require 3 arms and a trained monkey! Seriously, get 2 screwdrivers andat least one pair of pliers as this is hard! Slip a screwwdriver under the ring between the rubber folds. Slip another one opposite from this one and use a pliers to pull the ring free. Its hard but you can do it. Reverse the process when installing the new one. Make sure you have already aligned the inside up top for the air vent for the dry tube. Use a zip tie to seal that part around the dryer vent tube. Tighten the inside clamp before putting the ring back on the front! Have fun!
Splendide 2000S... | Answered on Dec 08, 2015
drain out the water by putting the hose low down also disconnect electricity
Splendide 2000S... | Answered on Jul 06, 2015
Splendide 2000S Vented Washer/Dryer Logo
121 questions posted
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Splendide Washing Machines
Most Popular Question
need drum baffles 2 broke off
  • Washing Machines
