20 Most Recent Frigidaire 14 Cycle Tumble Action Washer Questions & Answers
replace capacitor on motor
Frigidaire 14... | Answered on Feb 23, 2018
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Frigidaire 14... | Answered on Apr 10, 2016
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Frigidaire 14... | Answered on Mar 31, 2015
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Frigidaire 14... | Answered on Nov 23, 2013
Good Afternoon Leonard, thank you for your inquiry! If the washer was recently installed or moved to a different location, confirm that the hoses are connected correctly. Otherwise, the unit may be experiencing a communication issue with the control not responding accordingly or have a faulty water valve. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts. Experienced techs also usually warranty their labor just in case something else is the root cause of your initial problem.
Frigidaire 14... | Answered on Aug 29, 2013
E22 is usually a control board failure.
Frigidaire 14... | Answered on Aug 03, 2013
Your drain hose might be clogged. Disconnect it and try to run water through it.
Frigidaire 14... | Answered on Dec 01, 2012
Bad door lock switch
Frigidaire 14... | Answered on Aug 13, 2012
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Frigidaire 14... | Answered on Nov 23, 2011
If the tub will not agitate or spin the clothes out, your suspicions are correct. You will need to replace the "control assembly". Just remove the 2 screws on the front bottom kick plate and remove it. The controller is located on the right back side of the unit. Here is a link to the new controller.
Frigidaire 14... | Answered on Aug 22, 2011
Thanks for stopping by:
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some de-greaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa!!
Frigidaire 14... | Answered on Aug 03, 2011
A possible simple repair can be attempted at the hinge of the door place a towel/washcloth/or other suitable clothing to add a soft jamming space and GENTLY!!! push the DOOR in an attempt to close it, place one hand at the normal closing area and the other opposite 1/3 of the way from the hinge. If there is not enough wedge fold over garment at hinge and make it thicker do this until door will close properly.
Frigidaire 14... | Answered on Apr 02, 2011
Frigidaire 14 Cycle Tumble Action Washer Logo
91 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
clear loc code frigidaire washer
  • Washing Machines
