20 Most Recent Zeiss German Ww2 - Carl Jena Jenoptem 7 X 50w Multi-coated Binoculars With Case Questions & Answers
Google several vintage binocular web sites like this one:
http://www.collectorsweekly.com/military-and-wartime/world-war-two
and check Ebay for similar items.
Zeiss German Ww2... | Answered on Feb 22, 2015
Use the focus control. Look in the manual.
Zeiss Optics | Answered on Feb 06, 2019
The focussing wheels are in the middle of the hinged mount - rotate them until the image is in focus.
Zeiss Optics | Answered on Nov 03, 2018
Why not consult the store where you bought them ?
Zeiss Optics | Answered on Apr 14, 2017
You likely have a set built between 1919 and 1930. If you go to this site (
The history of the telescope the binocular ) and scroll down (or search) to areas with Zeiss Binoculars, there are a number of files that have the information on runs. In my case, I looked at the Spreadsheet attached to the Zeiss Binocular Models entry, which , between lines 150 and 168, notes that binocs with the Lena logo were made from 1904 to 1945, and that serial numbers above 1 million began in 1919 and above 1,550,000 began in 1930, putting your pair in there more or less in the middle.
Cheers!
Zeiss Optics | Answered on Feb 09, 2016
I know it's kind of general but between 500$ and 3000$
Zeiss Optics | Answered on Dec 25, 2015
1. Remove the lens covers, if they are in place.
2. Set the diopter on the right barrel eyepiece. The function of this setting is to adjust between vision differences between your eyes if you are NOT wearing corrective lenses. Set to zero if you do have corrective lenses on (glasses or contacts). For proper diopter adjustment see this article: Binocular Selection Guide.
3. Most binoculars will hinge in the middle to allow for differences in the spacing between the eyes. Set the spacing to fit your eyes.
4. Adjust eye cups. Each eyepiece will have a means of maintaining the correct eye relief for the user. On quality binoculars the rim of the eyepiece will extend and retract as you twist the eyepiece rim. Move all the way in if you are wearing eyeglasses or adjust out if not wearing eyeglasses. You will know if they are set correctly when you look through the binoculars and check to be sure that the circular edge of the view should be sharp and not fuzzy. At this point we are not looking at any object in the view but rather the perimeter of the view. You may need to adjust the eye cups again to compensate. On lower cost binoculars the eyecup may only be a rubber lip that you either fold over (the "in" position) or out.
5 Raise binoculars to your eyes and use one finger to adjust the focus wheel on the center shaft between the two barrels, until the view is in sharp focus. If viewing for extended periods you may want to keep your elbows down near your side as this will increase comfort while viewing.
Final safety tip: Do not look at the sun through binoculars.
Many people enjoy observing nature with binoculars. Having them handy is key. Hunting, astronomy, marine use, and stadium sports are a few more activities where having a pair of binoculars can make a real impact to your experience.
Zeiss Optics | Answered on Jun 06, 2015
That is quite surprising because Zeiss makes very good scopes and the optical quality is quite exceptional. You are an experienced hunter and you have other scopes to compare, so I believe that things like checking to be sure that a lens cap is removed has been checked. If you need service you can contact an authorized dealer such as http://www.rcsoptics.com/zeiss-scopes or http://www.zeiss.com alternately you may call Zeiss direct at 800-441-3005
Zeiss Optics | Answered on Jun 02, 2015
Zeiss German Ww2 - Carl Jena Jenoptem 7 X 50w Multi-coated Binoculars With Case Logo
1 questions posted
Top Zeiss Optics Experts
Inky Fingers
Inky Fingers
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
View Most Popular
Zeiss Optics
  • Zeiss Optics
Most Popular Question
find value antique carl zeiss jena
  • Optics
