20 Most Recent
Acer Altos G540 Server (G540-50039) Questions & Answers
I open side door window for removing hard disk and
It seems to be that side door is not properly closed. Please reopen side door close it again. If it still not work, let's clean up dust from sensor and then try again. Also, please check whether hard drives are properly connected or not.Please let me know if it still does not work.Regards,Kaushik Patel
Operating system not found
Hello, I recommend going into your BIOS and making sure your system is detecting the hard drive(s). If not, recheck your cable connection at the drive and the board. If it is detecting the drive, make sure it is set to be one of the boot drives(I would make it 2nd to the CD-ROM) and reboot your server. If you get the same error, you will need to reinstall the os. Good LuckC2Solutions
PXE-E61
1.) Verify that both the local and remote network interfaces are connected AND enabled/configured.
2.) Replace the cable.
If the system no longer reports a "Media test failure" error then the physical layer is good. Either your system will begin to PXE boot or you will need to verify that a PXE server is available/reachable in the same subnet/VLAN. (Barring any ACL issues, etc.)
Not much else to cover here. Considering this issue closed.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
