20 Most Recent
Whirlpool ED2GHEXN Side by Side Refrigerator Questions & Answers
Ice maker doesn't work. How do I check to see if
go behind the fridge where the water comes into it. the hose should go into a valve. if you have water and ice in door. there will be two hoses coming out the other side. what I did was find the hose that goes up to the ice maker and unhook it and there was no water coming out while it was trying to make ice. that valve is replaceable and are even on ebay. on mine the water worked in the front door, but ice maker did not. I think the valve is common problem.
4/7/2011 2:51:41 PM •
Whirlpool...
Answered
on Apr 07, 2011
How do you clean the
condenser coil ? remove bottom grille use long condenser cleaning brush available at most hardware or bldg. supply.
12/10/2010 3:57:44 AM •
Whirlpool...
Answered
on Dec 10, 2010
I have a whirlpool Refrig ed2ghexnt00 the ice
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 2:02:44 AM •
Whirlpool...
Answered
on Oct 01, 2010
Ice maker will not fill up with water
The water inlet valve is bad . Also check the tube going to the icemaker inside , to see if it is frozen as this is also caused by a bad water valve ( the piece which the wall water line connects to on the refrig .)
8/26/2009 2:02:19 PM •
Whirlpool...
Answered
on Aug 26, 2009
Everything freezes in the refrigerator bottom
Make sure the vents from the freezer to the fridge are not blocked by ice etc. One is at the bottom and one at the top. The on at the top is adjusted open or closed when you adjust the fridge temp. Make sure it's working. Also make sure the fan in the freezer is circulating the air from the freezer through the vent at the top.
8/26/2009 2:05:16 AM •
Whirlpool...
Answered
on Aug 26, 2009
