20 Most Recent Marantz DV4001 DVD Player Questions & Answers
In this case, you should use YPbPr (component) type of connection. It will allow you to watch TV in HighDef. without HDCP conflict.
Marantz DV4001... | Answered on Dec 23, 2009
Unplug the AC ..Let it set for a few minutes. PLug it in.
If no display still , it may be the backlight for the display that's quit.
Let me know,
Scott
Marantz DV4001... | Answered on Apr 11, 2009
Open the case and take it out manually.
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Marantz DV4001... | Answered on Jan 15, 2009
Make certain DRC (night mode, or whatever your specific model calls it) is OFF, and Make sure that Audyssey Dynamic Volume is OFF and Audyssey Dynamic EQ is ON!
The Dynamic Volume being ON is the most common cause of what you describe, as is directly limits the peak.
Marantz... | Answered on Apr 21, 2019
My first question is was it a Genuine Marantz replacement bulb, or simply a bulb advertised as "compatible".
There are an overwhelming number of bad luck stories about Marantz owners trying to save a few dollars by purchasing non-Marantz bulbs, and they always regretted it.
Usually the bulbs work for a brief time and then don't work.
I would urge you, if you did buy a bogus "compatible" bulb, to buy a genuine replacement.
If you wish to get some details; check the site linked here. Pull up older posts.
Marantz... | Answered on Mar 12, 2019
go into menu and reset to factory specs
Marantz... | Answered on Oct 07, 2018
then you can not use it the way you think it works . direct is the only way they work
Marantz... | Answered on Apr 24, 2018
Marantz DV4001 DVD Player Logo
Popular Tags
11 questions posted
Top Marantz Televison & Video Experts
Ekse
Marvin
Marvin
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Televison & Video
Most Popular Question
marantz dv 4001 front display not
  • Televison & Video
