20 Most Recent Marlin Model 60 .22 Cal Rifle Questions & Answers
http://pdfs/manuals/MFC_Self_Load_RF_Tube.pdf
Marlin Model 60... | Answered on Apr 07, 2017
On Marlin-branded Model 60 rifles, the first two digits of the serial number indicate the year of manufacture. For example, if the serial number starts with 18... The 18 is significant, for subtracting it from 2000 gives the date of manufacture for the rifle, 1982. Likewise, a serial number starting with 17 would be a rifle manufactured in 1983.
This method has not been uniformly followed. It is valid only from 1971 through 1999. Prior to 1971, the first two digits indicated the year of manufacture. For example, a rifle with a serial number starting with 70... would have been made in 1970. Starting in 2000, this same old method has returned; the first two digits once more indicate the year of manufacture directly, with no subtraction required.
Fixya does not do appraisals.
Marlin Model 60... | Answered on Oct 08, 2016
single action bolt try pulling the trigger as you push the bolt home
that will remove the obstruction to the bolt movement
Marlin Model 60... | Answered on Sep 11, 2016
Often with semi-automatic rim fire rifles, the most common cause of jams/failures to feed are related to improper cleaning. Most of these low-powered rifles utilize a blowback action to fire, and thus require a clean breech and chamber to provide proper obturation of the cartridge. Give your rifle a thorough cleaning, including a detail strip and clean. If you are experiencing other types of stoppages such as failures to extract or failure to feed, you may be experiencing a mechanical issue such as a worn extractor claw, or a weak magazine follower spring.
Marlin Model 60... | Answered on Nov 15, 2015
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
http://oldguns.net/sn_php/marlinlookup.php
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
Marlin Model 60... | Answered on Jan 19, 2015
TRY THIS LINK
Marlin Model 60... | Answered on Jan 04, 2015
Check which part is hotter than others, see if applying of a lubricant help in solving the jamming problem of your rifle.
Marlin Model 60... | Answered on Nov 08, 2014
If you mean year of manufacture, it's 1983
Marlin Model 60... | Answered on Jul 18, 2014
The year of manufacture for 17 = 1983
Marlin model 60s sell for $160 or so currently. Less than $100 in the 70s/80s. Perfect condition, used should bring from $80 to $120 depending on model.
Marlin Model 60... | Answered on Jun 23, 2014
1984
Marlins after 1948 use a system where you subtract the 1st two digits of the serial number from 100, to get the LAST two digits of the year it was made.
In your case, serial number 16370112 - 1st two digits = 16
100 - 16 = 84 = 1984
Marlin Model 60... | Answered on Feb 17, 2014
Marlin Model 60 .22 Cal Rifle Logo
39 questions posted
Top Marlin Optics Experts
RichardL
RichardL
ray gallant
Tom Chichester
Are you a Marlin Optic Expert? Answer questions, earn points and help others
View Most Popular
Marlin Optics
  • Marlin Optics
Most Popular Question
serial range marlin model 60 18 shot
  • Optics
