20 Most Recent Bosch Nexxt 500 WFMC3301 Front Load Washer Questions & Answers
Door won't unlock
Bosch Nexxt 500... | Answered on Jul 01, 2019
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Bosch Nexxt 500... | Answered on Dec 04, 2017
had this once before
A wire from an under wire bra found its way in-between the inner and outer drum
every now and again it would find its way to the seal and tear it
then one day the drum started making a loud grinding sound
on further investigation we found the wire
that fixed both problems
Bosch Nexxt 500... | Answered on Nov 16, 2017
Hi.
Here manual : BOSCH WVF2000 Washing Machine.PDF
Here parts manual : WVF 2000 Bosch-Spares.pdf
Regard
Bosch Nexxt 500... | Answered on May 05, 2016
well if theres more water in it now then when you took clothes out , id fail to se how its a drain issue , no id lean towards the inlet solenoid valve have a small bit of debris keeping it from closing all the way , this will probably need replacing
Bosch Nexxt 500... | Answered on Mar 18, 2016
The control board is seeing the door as open even though it may be closed. Here is how to repair it:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
Bosch Nexxt 500... | Answered on Nov 15, 2015
Water temperature sensor is defective and needs to be replaced.
Here is how you repair it:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-codes-er%3a05-and-er%3a06/2
The control board is seeing the door as open even though it may be closed. Here is how to repair:
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
sorry but you need to call a repairman .,sounds like the door switch or the main control has failed
Bosch Nexxt 500... | Answered on Nov 14, 2015
Door latching mechanism is bent out of position and needs to be realigned.
Bosch Nexxt 500... | Answered on Oct 14, 2015
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
The door typically locks as a result of the unit failing to drain, so....
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open and you've removed the items you wanted. Unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets".
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Bosch Nexxt 500... | Answered on Aug 09, 2015
E13 indicates your input voltage is to high
also can happen with faulty motor/ brushes
Bosch Nexxt 500... | Answered on Jul 12, 2015
The programmer itself might be at fault
No cycles complete .... but does the machine stop at the same part of each cycle, i.e. the rinse or the spin. If it does you can
ascribe the fault to a particular component.
If it is stopping at different points it would probably be the programmer.
A technician should be able to definitively diagnose the fault
Bosch Nexxt 500... | Answered on Jun 22, 2015
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
329 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
error code e 01
  • Washing Machines
