20 Most Recent
Rival RC61 6-Cup Rice Cooker Questions & Answers
Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
No instrution manual
You are an *******....Just to be blunt....This person is asking how to cook the rice to water ration in the rival 6 cup rice cooker and that ratio is like other ways to cook rice, which you are completely wrong about maybe you should take some lessons on how to cook. Its 1 PART RICE TO 2 PARTS WATER....NOT EQUAL, and in the cooker its 2 cups rice and 4 cups water makes a perfect pot!
Rival 6-cup rice cooker does not work
I have had THREE different cookers over the past year and ALL THREE have done the exact same thing. It has to be electrical and I suspect it blows an internal fuse...then it is no longer working. This is awful. I would never recomend it to anyone.
Rice cooker lid replacement?
if you still have the reciept the best thing that i would suggest is to take it back to the store or call the manufacturer and they will send you out another under warranty cause there should be a 1 year warranty on the unit.
I have acquired a rival
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
I have purchased a 6
Hi there.
You can download Owner's manual at http://www.rivalproducts.com
Regards.
Where can I get a
Hi there.
You can check for the nearest authorized service and parts provider in your area by visiting http://www.rivalproducts.com
