20 Most Recent Canon PowerShot SD850 IS Digital Camera Questions & Answers
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Canon PowerShot... | Answered on Jul 11, 2019
Check your warranty to see if it is within the factory repair period. If not, you need to have a Photoshop pro. do the job. If you try, and you fail, all that is left are parts. Don't take that chance.
Canon PowerShot... | Answered on Jan 15, 2018
just down load it
and then you click on the downloaded file and it should install the software.
the link below will automatically detect the windows operating system you are using if you are using windows
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/support-point-and-shoot/powershot-sd-elph-series/powershot-sd850-is?tab=drivers_downloads
Canon PowerShot... | Answered on Sep 04, 2017
Hi
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.
Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Please do rate this solution as FixYa and revert for further assistance. Thanks
Rylee
Canon PowerShot... | Answered on Jan 14, 2015
Make sure you are in the "postcard" mode or you can't turn the feature on.
Canon PowerShot... | Answered on Jan 05, 2015
fuji s100fs camera displays read error when viewing pictures on the sd card
Canon PowerShot... | Answered on Jun 20, 2014
Hi. Check in the menu to see is the camera set up to "talk" to a PC, you should be able to get the info on how to do this in the camera manual.
Canon PowerShot... | Answered on Apr 22, 2014
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Canon PowerShot... | Answered on Feb 21, 2014
Canon PowerShot SD850 IS Digital Camera Logo
181 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
lens error restart camerai turn camera
  • Cameras
