20 Most Recent HP Compaq WF1907 Monitor Questions & Answers
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
HP Compaq WF1907... | Answered on Oct 30, 2019
Try carefully reseating your memory modules and your video card.
HP Compaq WF1907... | Answered on Apr 30, 2019
I have just opened an HP W1907. It does not open from the back like Dell!!! The black plastic bezel with the HP logo on the front must be removed.I pried mine lose and broke most of the plastic nibs that hold it in place. From examining the bezel, it appears the a thin hook should be slipped in between it and the light gray plastic then pry up the back of the black bezel. The nibs on the black plastic bezel are facing downward and you must somehow lift them up and over the matching locks on gray piece. If you pry on the black back piece, as in Dell, you will break off four post the have screws put in from the front.
I hope this helps.
NKN
HP Compaq WF1907... | Answered on Mar 02, 2015
If you do not log out of facebook when you leave it, it will not ask you to log on when you go back.
HP Compaq WF1907... | Answered on May 29, 2014
Change your preset mode to factory default/normal (maybe ambient sensor?)
HP Compaq WF1907... | Answered on Apr 25, 2014
Computer to monitor audio cables are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=176
HP Compaq WF1907... | Answered on Apr 23, 2013
DVI is a Digital Video Input/Interface. I think what happened is you have changed your inputs on your monitor but that is only if your monitor has several different types of inputs. Check for that and if so then switch your input on your monitor.
HP Compaq WF1907... | Answered on Jan 21, 2013
HP Compaq WF1907 Monitor Logo
168 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
w1907 monitor goes blank
  • Computers & Internet
