20 Most Recent Whirlpool ED2FHGX Side by Side Refrigerator Questions & Answers
After changing water filter in
first check the water inlet tap
if the water from the tap does not has moulds then your refrigerator has moulds in the water line
for this you need to dispense water regularly untill the moulds gets lesser and lesser
also observe if that mould is really a mould or something is coming off your refrigerator dispenser
could be silica from previous filter
cannot confirm unless you observe the mould.
Thanks
10/27/2017 6:37:51 AM • Whirlpool... • Answered on Oct 27, 2017
NEED TO REMOVE DOOR HANDLES
hello,
this are the instruction to follow below
1.Check out how the door panels are attached to the car. Most panels usescrews and bolts but others have snap-in fittings. Gather all the toolsyou need for removing the door panels. If the panel is attached withscrews and bolts, you need a screwdriver or ratchet and socket. Cardoor panels with snap-in fittings are easily removed with a flatheadscrewdriver.
2Locate where the screws and bolts are before starting. These areusually found in the arm rest area, along the bottom or sometimes nearthe door lights.
3 Roll down the car door window. Begin removing all screws and bolts thathold the door panel onto the car. If your car has snap-in fittings, prygently on the bottom corner of the door panel until the fittings popout.
4.Remove the power window control panel if your car has power windows.The control panel should pry out easily, and then you unplug the wiringharness from the back and place it to the side.
5Use an L pick and flashlight when locating a manual window crank. Lookbehind the window crank and slide the pick under the edge of the metalclip that holds the crank in place.
.Remove the clip and pull the crankoff.Remove the door handle by unscrewing the small screw located in thecenter. Gently pull the door handle out until you see the back of thehandle and unclip the rod from the door handle. This should remove thehandle unless the handle and door lock are attached, then you justunclip the rod from the lock and remove them both together.
7.Unscrew the cap off rear upper corner doorpanel locks. These don't have a rod attaching them to the handle andunscrew separately from the door handle.
8.Pop the door panel off after you've removed everything. Gently pry onthe bottom edge of the door panel until it releases. Pull out and up tocompletely remove the door panel.
please do all this instruction with care thank and
thanks for using fixya.
  • Step 8 Pop t
  • Read more: How to Remove Car Door Panels | eHow.com http://www.ehow.com/how_2164577_remove-car-door-panelsremove-car-door-panels.html#ixzz0vxRgii6t
    7/14/2014 11:13:46 PM • Whirlpool... • Answered on Jul 14, 2014
    0answers
    0answers
    Ed22pw
    Be the first to answer 5/26/2013 3:17:29 AM • Whirlpool... • Posted on May 26, 2013Be the first to answer
    WHAT IS THE CAPACITY OF
    11/10/2011 5:25:00 PM • Whirlpool... • Answered on Nov 10, 2011
    I have a Whirlpool side
    NOTE: This
    is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
    But the solution is in here generically, if you read and study the solutions very,very carefully.
    Check Temp inside freezer. It has to be down to about 10 or 15 degrees
    This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
    The ref. temp should be about 33-35
    The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
    The higher the number you turn it up to is the coldest
    The icemaker is 110v
    See if water is in icemaker.
    Pour water in Ice Maker and wait to see if it ejects.
    If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
    attaches to water line out of wall)
    If it doesn't eject then it is a faulty Ice Maker.
    If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
    First I would check the fan in the freezer. Listen to see if it is running
    It moves air to the ref from the freezer
    Then check to see if freezer control is turned WARMER, which makes the Ref. colder
    Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
    the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
    Also this might be a common Defrost problem, Ice
    is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
    Take out back panel of freezer to check for ice buildup. The coils should be clean.
    There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
    Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
    Also check fan undernearh Ref in the rear
    Clean condenser coils underneath
    If you still have trouble GO HERE:
    http://www.applianceaid.com/procedures.html
    I'm
    including my article on Refrigerator Repair for your help and convenience.;
    Please click or copy and paste into browser for Article
    http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
    Thanks for using fixya
    Leo Ponder
    imufo2
    PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
    8/22/2011 2:25:37 PM • Whirlpool... • Answered on Aug 22, 2011
    I have a Whirlpool refrigerator
    There is most likely a crimp in the line or some other blockage.
    Remove the toe kick plate across the bottom front of the refrigerator.
    You will see the water line to the door. The pkastic line is about 3/8 inch in size.
    There is a plastic coupling that needs to be disconnected.
    Have a glass handy and have someone push the water button while you catch the water.
    If you get a good stream of water under the refrigerator,the restriction is in the door tubing.
    If you do not get good flow,the water valve could be disconnected in the rear and run the water button again.
    Ifr you then get good flow the restriction is in the tubing inside the fresh food side.
    If you get poor flow at the valve,the valve is bad.
    3/26/2011 11:48:27 PM • Whirlpool... • Answered on Mar 26, 2011
    My kirkland refrigerator is not
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
    If your refrigerator is running but warm, then...
    Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    Refrigerator Condenser Coil Cleaning Refrigerator Repair
    Refrigerator Troubleshooting Refrigerator Compressor
    Refrigerator Compressor Start Capacitor and Start Relay
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    3/19/2011 3:17:48 AM • Whirlpool... • Answered on Mar 19, 2011
    MY SIDE BY SIDE Whirlpool
    A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced.Thanks.
    2/4/2011 6:43:22 AM • Whirlpool... • Answered on Feb 04, 2011
    Freezer isn't working
    make sure coils are clean, fan motor behind unit is working ,and defrost timer is not stuck
    1/27/2011 7:06:29 PM • Whirlpool... • Answered on Jan 27, 2011
    I have a whirlpool refrigerator
    Defrost it periodically cause if the fan is frosty and do not work the cold air will not be disposed even on the fridge ..and this can happen ...Another thing to check is the dispenser coil ...cause if it freezes this will make it accumulate ice and not cool like it should ..
    In both cases a periodic defrost (once a month will fix it )
    1/5/2011 8:01:55 PM • Whirlpool... • Answered on Jan 05, 2011
    My ED5FHGXKQ02 Side by Side is not cooling. It is
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
    Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    heatman101
    10/6/2010 3:30:35 AM • Whirlpool... • Answered on Oct 06, 2010
    Hot doors. fridge does not work. works a little
    open the evaporator coil access panel in the back wall area of the freezer and see if its iced up,is so take a hair dryer and defrost it,then you may need a new defrost heater element or defrost control be it either timer or adaptive,if the coil is covered with ice it cannot cool the unit properly even if the fan is operating
    7/5/2010 12:10:07 PM • Whirlpool... • Answered on Jul 05, 2010
    Whirlpool ED2FHGX Side by Side Refrigerator Logo
    58 questions posted
    Top Whirlpool Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
    View Most Popular
    • Whirlpool Refrigerators
    Most Popular Question
    side side whirlpool
    • Refrigerators
