20 Most Recent
Audiovox FPE1907 19 in. LCD Television Questions & Answers
Code for cablevision remote control
Hello Monica24g. I also have Cablevision and found the codes I was looking for. I assume you have an Audiovox (fpe1907) television. Here are some codes you can try: 076 103 043 035 224 228 078. Press the "TV" button and the "SELECT" simultaneously for 3 seconds. The IO button will light up. Enter one of the codes, then press the "TV" button again. I hope this helps!
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
- Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
- Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
- Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
- Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM •
Audiovox...
Answered
on Feb 16, 2023
I have a Audiovox d1988 and the screen won't play. I have sound but no picture. Help!!!
Jim,
First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you.
Hope this helps,
Best regards
3/8/2019 11:36:14 PM •
Audiovox...
Answered
on Mar 08, 2019
